HI Matt, yeah...i changed the computer and it is still gives me the same error. Hopefully, someone else will comment on my post.I tried to specify the individual filename and it doesn't read the file name, it reads as 'band 1', which is weird. I changed this line:arcpy.env.workspace = "S:/Work/Risa/Trials_Errors/InputFiles02/ppt_1971_07.tif"
and the output is:[u'Band_1']
Processing: Band_1
File "S:\Work\Risa\Python codes\zonalStats_test02.py", line 39, in <module>
saveRaster = arcpy.sa.ZonalStatistics(ZoneData, "ZoneField", inRaster, "MEAN", "DATA")
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5787, in ZonalStatistics
ignore_nodata)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5780, in wrapper
ignore_nodata)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 999999: Error executing function.
Failed to open raster dataset
Failed to execute (ZonalStatistics).
