Any reason Field Calculator will work with VB but not Python or Python 9.3
2532
01-28-2011 09:48 AM
DanielSheehan
New Contributor II
So with some geodatabases - specifically this one I've been using from converted KML's - I can calculate fields, even just something simple as calculating a new field as one of the older fields, using VB but not Python, is there something up with the geodatabases - like any idea on why this might happen? I've tried a ton of simple expressions and only VB Field Calculations work and Python Expressions don't in these particular geodatabases.
FreddieGibson
Occasional Contributor III
Hi Daniel,
Not sure if you're still having this problem, but if you are could you upload some screenshots of the expressions you're using?
