Luke, or anyone else...
I too am learning to append and user fieldmap, flieldmappings to get my fields squared away.
basically I'm appending data into a "shell" featureclass that is empty. There's only a few fields I'm appending and trying to match.
I'm able to add ONE field change with this script:
(append and target layers are defined earlier in the script as well as importing the arpy library
append_layer = outputclip
target_layer = out_name
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(target_layer)
fieldmappings.addTable(append_layer)
field_to_map_index = fieldmappings.findFieldMapIndex("PropertyAddress")
field_to_map = fieldmappings.getFieldMap(field_to_map_index)
field_to_map.addInputField(append_layer, "Addy_Concat")
fieldmappings.replaceFieldMap(field_to_map_index, field_to_map)
arcpy.Append_management(append_layer, target_layer, "NO_TEST", fieldmappings, "1")
So, this works for me. I end up appending the "Addy_Concat" field into the "PropertyAddress" field. Great.
But I have 3 other fields to do this with. So I used this:
list_of_fields_we_will_map = []
list_of_fields_we_will_map.append(('Addy_Concat', 'PropertyAddress'))
print(*list_of_fields_we_will_map, sep = ", ")
for field_map in list_of_fields_we_will_map:
field_to_map_index = fieldmappings.findFieldMapIndex(field_map[0])
field_to_map.addInputField(append_layer, field_map[1])
inData = [append_layer]
arcpy.Append_management(inData, target_layer, "NO_TEST", fieldmappings, "1")
I keep on getting this error:
File "<string>", line 119, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\arcobjects\arcobjects.py", line 666, in addInputField
return convertArcObjectToPythonObject(self._arc_object.AddInputField(*gp_fixargs(args)))
RuntimeError: FieldMap: Error in adding input field to field map
Specifically, it's this line (119) that's causing issues:
If you noticed, I remarked out my multi fields to let the list just take the one field match combo that worked in the simpler, non-list script.
Still throws this error.
I'm confused how this list loops works. Not sure how it's figuring out position 0,1 with the case like
Any ideas what I'm doing wrong here? Or what I can do to try accomplish what I want to do?
