ArcGIS Python API Overwrite Feature Service Not Working
775
5
07-24-2023 11:00 AM
ArizonaGIS
****Edit. When I publish a zipped file geodatabase with only layers and perform the overwrite function, it works as expected, but when I publish a zipped file geodatabase with multiple layers and tables, that is where it is erroring out on me. I believe the ArcGIS Python API and its overwrite function are limited to one or the other kind of dataset, not a combination of both layers and tables.
I am trying to overwrite a feature service on ArcGIS Online using the ArcGIS API for Python. The code I am using is:
# Import necessary libraries
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
# Log in to your AGOL account
gis = GIS("https://www.arcgis.com", "Your Username", "Your Password")
# Access the service using its ID
service_item = gis.content.get('d4a4d33b25434986a249666c64daf9dc')
# Access the feature layer collection associated with the service
flc = FeatureLayerCollection.fromitem(service_item)
# Define the path to your .gdb.zip file
gdb_zip_path = 'C:\\GIS_Project\\Navajo County ETL Process\\DATAMARK VEP Dataset\\Navajo_County_ETL.gdb.zip'
# Overwrite the feature service
flc.manager.overwrite(gdb_zip_path)
However, when I try to run this script, I get the following error:
`TypeError: can only concatenate str (not "NoneType") to str`
The traceback points towards this line of code:
`flc.manager.overwrite(gdb_zip_path)`
From my understanding, this error might be occurring because the item I am trying to overwrite is not inside a specific folder in my content, causing issues when the API tries to concatenate a string with `None`. However, I have confirmed that this item is at the root of my content and not inside a specific folder.
Has anyone encountered this issue before, and if so, how did you resolve it?
Shauna-RaeBrown
The following line of script allows me to overwrite an existing file.
ArizonaGIS
@Shauna-RaeBrown I believe that would work as expected if I was working only with feature classes but communicating with a feature class to a feature service would require using the ArcGIS Python API.
by Anonymous User
Not applicable
From the docs of overwrite- Only hosted feature layer collection services can be overwritten.
I think you nailed it in your edit; just upload separately.
ArizonaGIS
@Anonymous User Kind of odd that the manual way through AGOL of dropping a file geodatabase that contains both layers & tables is capable of an overwrite but using the ArcGIS Python API workflow it doesn’t work?
JakeSkinner
Esri Esteemed Contributor
@ArizonaGIS this could be another solution to try.
