At the end of this script that imports MXDs into an ArcGIS Pro Project I'm using the saveACopy function.
'''Import folder of MXD(s) into an ArcGIS Pro Project and save the project in a folder.
import arcpy, os
workspaceMXD = r"C:\gisfile\GISmaps\AtlasMaps\ATLAS_MAPS_20\TestFolder"
arcpy.env.workspace = workspaceMXD
mxdlist = arcpy.ListFiles("*.mxd")
aprx = arcpy.mp.ArcGISProject(r"C:\gisfile\GISmaps\AtlasMaps\MXDtoAPRX_tempdelete\MXDtoAPRX.aprx")
for mxd in mxdlist:
fullpath = os.path.join(workspaceMXD, mxd)
print("Importing: {}".format(fullpath))
aprx.importDocument(fullpath)
print("Currently {0} maps in Project file.".format(len(aprx.listMaps())))
aprx.listMaps()[-1].name = mxd.split("\\")[-1][:-4]
aprx.saveACopy(fullpath)
print("----done----")
Output
Importing: C:\GISmaps\AtlasMaps\ATLAS_MAPS_20\TestFolder\Union_Elem_81_B.mxd
Currently 2 maps in Project file.
Importing: C:\gisfile\GISmaps\AtlasMaps\ATLAS_MAPS_20\TestFolder\ValleyView_Unit_365U_B.mxd
Currently 4 maps in Project file.
Importing: C:\gisfile\GISmaps\AtlasMaps\ATLAS_MAPS_20\TestFolder\WillCounty_Elem_92_B.mxd
Currently 6 maps in Project file.
Importing: C:\gisfile\GISmaps\AtlasMaps\ATLAS_MAPS_20\TestFolder\Wilmington_Unit_209U_B.mxd
Currently 8 maps in Project file.
----done----
It saves an APRX file from the workspace folder for each imported MXD. But, a copy of the map is imported in each consecutive project. So, as seen here and in the Test Folder, by the fourth saved APRX file maps for the other three projects are also there.
That's why the file size of the APRXs increases by 400+ KB as the script loops through the folder.
I've also tried taking aprx.saveACopy(fullpath) out of the for loop. But, that only saves one APRX file with all maps in that one project.
How do I loop through the Test Folder and save a copy of the APRX file with it's corresponding map only?
As discussed at the bottom of my other post, ArcGISProject saveACopy seems only to allow full paths as a parameter.
importDocument() OSError
