arcpy calculate field expression
3043
7
03-13-2018 04:11 AM
RebeccaWatson1
New Contributor III
I am trying to create a file path and add it to a field by concatenating the path with a file name that is held in a field in my data.My path is a constant \Links\Sheets\Project\ and my Drawing_Name field has values like Drawing01.pdf, Drawing02.pdf etc.
I keep getting the error:
The SELECT statement includes a reserved word or an argument name that is misspelled or missing, or the punctuation is incorrect. Failed to execute (CalculateField).
The function is written like this...
# Process: Calculate Field
arcpy.CalculateField_management(Centroids, "URL", expression, "PYTHON_9.3", "")‍‍‍‍
 And for my expression I want something like one of these...
expression = "\"\\\\Links\\\\Sheets\\\\Project\\\\\"+ !Drawing_Name!"
expression = "\"\\Links\\Sheets\\Project\\{0}\".format( !Drawing_Name! )"‍‍‍‍‍
I want to end up with \Links\Sheets\Project\Drawing01.pdf in the field.
The first expression used to work, but seems to throw the error above now - I believe it is my punctuation which is the problem - can anyone help?
Thanks
Rebecca
Tags (3)
XanderBakker
Esri Esteemed Contributor
Although using the Field Calculator sounds like the easiest way of solving this, in many cases it is more complex due to double interpretation/parsing of the expression. I would seriously recommend you to use a cursor, like the one below:
import arcpy
import os
fc = r'your path to the fc or table'
fld_out = "URL"
fld_in = "Drawing_Name"
url = r"\Links\Sheets\Project"
with arcpy.da.UpdateCursor(fc, (fld_in, fld_out)) as curs:
    for row in curs:
        if row[0]:
            row[1] = os.path.join(url, row[0])
            curs.updateRow(row)
NeilAyres
Ever thought of using "/" instead. Too many back slashes... And those "" look a bit off.
RebeccaWatson1
New Contributor III
Thanks for your reply - I believe that I have to use \ for windows paths? Do you have any more pointers on how the " look off? I have tried various combinations of single and double quotes but with no luck.
RebeccaStrauch__GISP
try something like this
import os
myPath = r"\Links\Sheets\Project"
myPDFs = ['Drawing01', 'Drawing02', 'Drawing03']
for aPDF in myPDFs:
    pdfPath = os.path.join(myPath, "{0}.pdf".format(aPDF))
    print(pdfPath)
(I saw a flash that Dan just sent an answer...he might have a better way.  Haven't looked yet)
XanderBakker
import arcpy
import os
fld_out = "URL"
    for row in curs:
        if row[0]:
            curs.updateRow(row)
RebeccaWatson1
New Contributor III
Thank you - this has done the trick. You are right that the calculate field was just making the expression too complex. Stripping that out and using UpdateCursor instead has worked perfectly.
Thanks to everyone for their suggestions.
DanPatterson_Retired
Use raw notation 'r'
Don't put a backslash at the end of a path you are concatenating
pth =r"c:\temp\somepath"
f = r"\my.pdf"
pth + r"\Links\Sheets\Project{0}".format(f)
'c:\\temp\\somepath\\Links\\Sheets\\Project\\my.pdf'
# ---- or....
r"{}\Links\Sheets\Project{}".format(pth, f)
you don't need the 0, 1 etc in the {} if they are in order
for the future (ie PRO)
f-strings do make some things look tidy
f"{url}\{fld_in}"  # ---- f-string, sort of like "stuff".format(*args)
'\\Links\\Sheets\\Project\\Drawing_Name'
