arcpy calculatefield expression codeblock exponential
1674
7
03-16-2021 07:28 PM
SalahuddinAhmad
Hello colleagues
I am trying to use a formula in python. It is a raster dataset and I am trying to calculate a field based on an equation.
Here is the code
inTable = "C:/Data/A3_Large_projects/Fuelloadmodels/Data/GDB/Yr2021.gdb/combo"
fieldName = "Bark_load"
expression = "t_RF(!Bark_r!, !Bark_k!, !Bark_c!, !since_fire!)"
codeblock = """
def t_RF(Bark_r, Bark_k, Bark_c, since_fire):
  if since_fire >= 0:
      return 7.437 /(1+937.8 * Exp ( -1.905 *( Bark_r *(1 - Exp ( - Bark_k * since_fire ) )+ Bark_c )))
  else:
      return 999 """
arcpy.CalculateField_management(inTable, fieldName, expression, "PYTHON_9.3", codeblock)
End code
Error message starts
  File "C:\Data\A3_Large_projects\Fuelloadmodels\Python_script\Fuelhazard.py", line 126, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\management.py", line 3661, in CalculateField
    raise e
ExecuteError: ERROR 000539: Error running expression: t_RF(2.5, 0.2, 0.7, 1)
  File "<expression>", line 1, in <module>
  File "<string>", line 4, in t_RF
NameError: global name 'Exp' is not defined
Failed to execute (CalculateField).
End error message
I am relatively new in python. Trying to understand the error message. Will appreciate any help.
DanPatterson
You didn't import the spatial analyst
Exp (Spatial Analyst)—ArcGIS Pro | Documentation
from arcpy.sa import Exp
And I hope your code block is formatted properly because you copy paste won't work
Code formatting ... the Community Version - Esri Community
... sort of retired...
curtvprice
This is a raster dataset? You are using Calculate Field, it so sounds like !Bark_r!, !Bark_k!, !Bark_c!, !since_fire!) are all fields in a raster table. (Combine output?)
If that's the case, math.exp should be used not Exp here.
>>> import math
>>> math.exp(1)
2.718281828459045
However, if I am wrong and these are rasters, not fields in a table, @DanPatterson is correct and you should be doing something like
from arcpy.sa import *
outraster = 7.437 /(1+937.8 * Exp ( -1.905 * Bark_k ...
SalahuddinAhmad
exp.JPGThanks, @curtvprice for your help.
Yes, it is a raster dataset name "combo" and those are the field names from the raster table. I trying to calculate a field called "Bark_load" based on the following equation.
VB
Python
7.437 /(1+937.8 * math.exp(-1.905 *( !Bark_r! *(1 - math.exp(- !Bark_k! * !Since_Fire! )) + !Bark_c! )))
please note: exp is exponential function not Exp (Spatial Analyst)
I have a modelbuilder and this equation works there as VB and Python.
Thanks for any further help.
curtvprice
Here is how that works with the tool:
expr = "t_RF(!Bark_r!, !Bark_k, !Bark_c!, !since_fire!)"
cblock = """
def t_RF(rr, kk, cc, sfire):
    import math
    if sfire >= 0:
        return (
            7.437 /
                ( 1 + 937.8 * math.exp(-1.905 *
                    (rr * (1 - math.exp(-kk * sfire)) + cc )))
    else:
        return 999 """
arcpy.CalculateField_management(inTable, fieldName, expr, "PYTHON_9.3", cblock)
I should mention that arcpy.da.UpdateCursor is a more common way to do this with complex field calculations in Python (less overhead):
    import math
    if sfire >= 0:
        return (
            7.437 /
    else:
        return 999
with arcpy.da.UpdateCursor(inTable,
    ["Bark_load", "Bark_r", "Bark_k", "Bark_c","since_fire"]) as rows:
    for row in rows:
        bark_load, rr, kk, cc, sfire = row
        row[0] = t_RF(rr, kk, cc, sfire)
        rows.updateRow(row)
DanPatterson
exponent
7.437 /(1+937.8**(-1.905 * Bark_k ...
  exponents in python are **
2**4
16
curtvprice
Dan: the VB function and Raster tool Exp is "e to the value" not  ^ (VB) or ** (Python)
DanPatterson
grief... too many e E eE Exp EXP 's 😉
