Ok so I tried searching for an answer to this but to no avail, so hopefully someone can help me.
I'm running a python script I obtained from here: 39248 - Export each time slice from a NetCDF layer as a single raster (*.tif)
In the past I've had no problems with this script, however I have recently moved to ArcGIS v10.3 and I now get the following error:
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 12525, in CopyRaster raise e ExecuteError: ERROR 999999: Error executing function. Failed to open raster dataset Failed to execute (CopyRaster).
My first instinct was that python was not installed correctly, but I've removed and reinstalled ArcGIS and the problem persists. Can anyone help? Let me know if I need to provide more info.
Liam
