Hi Maxime
To create a Historical Marker from Python, an option is using comTypes. Following the next steps, you can create Historical Markers in a Enterprise Geodatabase from Python:
Environment: ArcGIS for Desktop 10.4.1 + Python 2.7
- Install comtypes-0.6.2.win32.exe (attached)
- Go to comtypes folder in "C:\Python27\ArcGIS10.4\Lib\site-packages\comtypes", and delete the automation.pyc, automation.pyo, safearray.pyc, safearray.pyo files. Edit the file automation.py and insert POINTER(BSTR): VT_BYREF|VT_BSTR, in the _ctype_to _vartype dictionary.
3. Delete all files in C:\Python27\ArcGIS10.4\Lib\site-packages\comtypes\gen
4. Copy the file Snippets.py (attached), into C:\Python27\ArcGIS10.4\Lib
5. From Python Script you must to implement a function to create the Historical Marker. (the example in the test.py file)
Hope this helps,
Edwin
