When using CreateTin in arcpy I can input a list of shapefiles if they have z-values like this:
arcpy.CreateTin_3d(outTin, CoordSys, ["feature1.shp", "feature2.shp"])
However now one feature has z-values and one has m-values. I can create TINs from the features individually like this:
arcpy.CreateTin_3d(outTin, CoordSys, "feature1.shp Shape.Z Mass_points <None>")
or
arcpy.CreateTin_3d(outTin, CoordSys, "feature2.shp Shape.M Mass_points <None>")
However if I try to put them into a list......
arcpy.CreateTin_3d(outTin, CoordSys, ["feature1.shp Shape.Z Mass_points <None>", "feature2.shp Shape.M Mass_points <None>"])
I get the following error:
File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\ddd.py", line 1735, in CreateTin
raise e
arcgisscripting.ExecuteError: ERROR 999999............
What's going wrong - the features work together if I generate the TIN using the GUI?
I found the answer - it wont accept lists with this notation - now I have to input my features in a single string separated by semicolons i.e.
"feature1.shp Shape.Z Mass_points <None>;feature2.shp Shape.M Mass_points <None>"
