arcpy.da.Editor Hanging up Script Tool
179
6
2 weeks ago
EvanMyers1
Has anyone run into the issue where 'with arcpy.da.Editor(workspace, multiuser_mode=True):'  doesn't do anything?  In my case, my script works up until this point, and just endlessly runs.  It doesn't reach the 'arcpy.AddMessage('starting edit')' part or anything within the with statement.  I end up having to ctrl+alt+del Pro just to get out.
import arcpy
import os
import sys
import geopandas
userInput = arcpy.GetParameterAsText(0)
inputDesc = arcpy.Describe(userInput)
workspace = os.path.dirname(inputDesc.catalogPath)
wsDesc = arcpy.Describe(workspace)
versioned = inputDesc.isVersioned
if hasattr(wsDesc, "datasetType") and wsDesc.datasetType == 'FeatureDataset':
    workspace = os.path.dirname(workspace)
with arcpy.da.Editor(workspace, multiuser_mode=False):
    calcCoords(userInput)
EvanMyers1
I am not sure what was preventing edits to the workspace but I ended up having to make a new database and test features to solve the issue.  I still really appreciated the help though!
BlakeTerhune
MVP Regular Contributor
Maybe something isn't right with your workspace manipulation. Try messaging out the workspace before you open the editor, then see if it works when you hard code that workspace path (or something else you know to work).
EvanMyers1
When I print out my workspace I get this:
userInput = "TestAssets"
print(workspace)
'F:\\GIS\\WORKING FILES\\TestProjects\\TestingDB.gdb'
BlakeTerhune
Okay, that looks fine. Now try an isolated test with the arcpy.da.Editor() with that workspace and see what happens.
workspace = 'F:\\GIS\\WORKING FILES\\TestProjects\\TestingDB.gdb'
    # Nothing else, just leave the script.
EvanMyers1
My script ran successfully.  I used the hard coded filepath, but I will not be able to do that for future use, as the other users keep their databases in different places.
If my script is getting stuck on the workspace, could it be a problem with the database itself?
BlakeTerhune
If that hard coded workspace path worked fine, then it's not a problem with the database. I see you are doing some other workspace path manipulation if the input feature class is in a feature dataset. Try some other variations of the path to see if you can get it to fail when hardcoded. My guess is that you're getting something in the workspace that is causing Editor to hang.
EvanMyers1
