arcpy.ListFeatureClasses doesn't work when using os.path.join
1555
08-17-2020 02:05 PM
AhmadSALEH1
Occasional Contributor III
 I couldn't figure out why arcpy.ListFeatureClasses() doesn't work when I set env.workspace = os.path.join (path,gdb)
and works when I set env.workspace = r"path to the gdb"!
here is an example:
The below script works in my IDE
import arcpy
#Solution 1
gdbANDpath=r"C:\ahmad data\data\MyProject5\f.gdb"
arcpy.env.workspace=gdbANDpath
fclist=arcpy.ListFeatureClasses()
print len(fclist)
prints >> 8
while the following script doesn't work and gives an error:
import arcpy
import os
#Solution 2
gdb_name="f.gdb"
gbd_path="C:\ahmad data\data\MyProject5"
gdbANDpath=os.path.join(gdb_name,gbd_path)
print len(fclist)
File "<module1>", line 31, in <module>
TypeError: object of type 'NoneType' has no len()
fclist here returns none and fails to create a list of feature classes in the gdb!
PS: Tested on  ArcMap 10.7.1 and 10.6.1, on more than one gdb
DanPatterson
MVP Esteemed Contributor
 import os
gdb_name="f.gdb"
gbd_path
Out[3]: 'C:\x07hmad data\\data\\MyProject5'
Now
gdb_name="f.gdb"
gbd_path= r"C:\ahmad data\data\MyProject5"
gbd_path
Out[5]: 'C:\\ahmad data\\data\\MyProject5'
a little "r" on line 2 goes a long way
... sort of retired...
AhmadSALEH1
I am under the assumption that os.path.join(gbd_path,gdb_name) does the same job as using the "r" before the path!
how I can get the same effect of "r" but in a  programmable why?
gbd_path is coming from a function that returns  the path as the sting
in python 3.X I was using
from pathlib import Path
p=Path(os.path.join(gbd_path,gdb_name))
this used to work, but I am not sure what to use in 2.7
DanPatterson
you provide this
n = "f.gdb"
g = "C:\ahmad data\data\MyProject5"
os.path.join(g, n)
'C:\x07hmad data\\data\\MyProject5\\f.gdb'  # ---- fails
This works
n = "f.gdb"
g0 = r"C:\ahmad data\data\MyProject5"  # ---- raw format
os.path.join(g0, n)
 'C:\\ahmad data\\data\\MyProject5\\f.gdb'
Or check pathlib in 2.7
Python 2.7.18 documentation
if you must use arcmap
or
n = "f.gdb"
g ="C:/ahmad data/data/MyProject5"
p = "{}/{}".format(g, n)
p
'C:/ahmad data/data/MyProject5/f.gdb'
which will work fine
JoshuaBixby
Regarding:
You are incorrect.  os.path.join won't convert or treat a regular string literal to a raw string literal.
>>> import os
>>> path = "C:\ahmad data\data\MyProject5"
>>> raw_path = r"C:\ahmad data\data\MyProject5"
>>> name = "f.gdb"
>>> print(os.path.join(path, name))
C:hmad data\data\MyProject5\f.gdb
>>> print(os.path.join(raw_path,name))
Your issue is that "\a" is a Python escape sequence for ASCII Bell (BEL) character.  If you don't properly escape it, or use raw string notation, that character will make a little chime on your speakers and then be removed from the string.
When you say "this used to work," I am guessing the path was different and didn't involve any Python escape sequences.
AhmadSALEH1
Thanks Joshua, this explains a lot.
