Arcpy: Make sure there's selection before execute 'Copy Features"
1221
08-31-2018 04:19 PM
helenchu
Occasional Contributor II
Hi
I use "Copy Features" tool to make a layer from selection.  It's crucial that I check for a selection first or it will copy the whole layer.  Please help me with that.  Thank you!
Tags (1)
RandyBurton
And something like this should also work:
selection = arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION",
                                                    where_clause="Field = 'Something'")
result = arcpy.GetCount_management(selection)
count = int(result.getOutput(0))
if count:
    print count
    arcpy.CopyFeatures.......
See: Get Count
You could use GetCount to count items in the layer before and after the selection and if selection is less than the original count and greater than zero then do the copy.
DanPatterson_Retired
for map and pro
Layer—ArcPy | ArcGIS Desktop
getSelectionSet ()
Returns a layer's selection as a Python set of object IDs.
which will be > 0 if there is a selection.
If you don't have a layer, then use MakeFeatureLayer first then delete if needed
RandyBurton
if count:
    print count
See: Get Count
