arcpy - new line in geoprocessing dialog window
6152
18
04-14-2015 12:52 AM
MarkWisniewski
I am currently using;
arcpy.AddMessage(arcpy.GetMessages())
and
arcpy.AddMessage(fc)
to tell me the features that are being processed by the geoprocessing tool in my script. Is there a way to seperate these in the geoprocessing dialog window by a line spacing because it looks cluttered?
DanPatterson_Retired
AddMessage only works in scripts associated with tools in ArcToolbox.  That error message means that the script you are using isn't associated with a tool.  If you are running a script outside of a tool in ArcToolbox, then you have to use the print statement.  If I want to have messages appear both in Arctoolbox's output dialog and when I run a script stand alone, then I do the following
msg = "my message here"
msg2 = "another message"
print msg, "\n", msg2         ( or print('{}\n {}'.format(msg,msg2))  using the newer print statement"
arcpy.AddMessage(msg + "\n" + msg2)
so you will have to clarify where you are running this and include your script portion
arcpy.AddMessage(arcpy.GetMessages() + "\n")
and/ or
arcpy.AddMessage("\n" + fc + "\n")
where "\n" is the newline in python and you have to concatenate them in AddM***
for arcpy.GetMessages you might have to cycle through the list and add a newline to each entry
msgs = arcpy.GetMessages()
for msg in msgs:
  arcpy.AddMessage(msg)
MarkWisniewski
Dan,
It appears \n isn't supported, I tried it in both statements above.
you enclosed it in double quotes and used the + to concatenate them ? as in the following
arcpy.AddMessage("Hello" + "\n")
MarkWisniewski
Sure did;
Error 000576: Script associated with this tool does not exist.
MarkWisniewski
Oops Dan,
My apologies, user error, I renamed a folder that was used for accessing the script in the toolbox. My error. Had to set filepath in script again.
arcpy.AddMessage ("\n" + fc) is kind of working but gets;
abc.shp
xyz.shp
123.shp
How can  I make the list please?;
abc.shp
xyz.shp
123.shp
just remove the...  "\n" +   ... if you are using AddMessage in a loop
MarkWisniewski
That works removing the "\n" in my loop, but I am after this affect;
Running script Clip...
abc.shp
xyz.shp
123.shp
The line space after "Running script Clip..."in the dialog box and before the shapefile name. arcpy.AddMessage ("\n" + fc) inserts this space, but also a space between shapefile names. How can I remove the space between the shapefile names?
somewhere at the very beginning of your script just add a line which is a blank message
arcpy.AddMessage("")
if you didn't add the "running the clip script your self
then in the loop your message remains the same
