Batch processing of polygon to raster with multliple fields
3309
05-05-2016 10:23 AM
EstebanBarbosa
I am attempting to create a script that will use the polygon to raster conversion in a batch processing function that creates multiple rasters based on different fields specified. I am wanting to do this for multiple feature classes within a folder. So far I have been able to get it to run for only one of the desired feature classes but not both.( There are two within the folder). Here is my script.
    import arcpy
    from arcpy import env
    #Set environment settings
    env.workspace = r"E:\GISC605GISDevelopment\Python Project\RivCounty"
    #Set local variables
    valField = ["TOTAL_PRO","OWN","COLLEGE_ED","Foreign","Per_INC2","TOTAL_25MI"]
    outRaster = r"E:\GISC605GISDevelopment\Python Project\RivCounty\Group"
    #List features
    fcList = arcpy.ListFeatureClasses()
    print fcList
   for fc in fcList:
       for field in valField:
           arcpy.PolygonToRaster_conversion(fc, field, outRaster+str(valField.index(field))+".img")
JakeSkinner
Esri Esteemed Contributor
Hi Esteban,
I believe you are overwriting the first outputs with your for loop.  Try the following:
x = 1
for fc in fcList:
        arcpy.PolygonToRaster_conversion(fc, field, outRaster+str(x)+"_"+str(valField.index(field))+".img")
     x += 1
JakeSkinner
Hi Esteban,
x = 1
for fc in fcList:
     x += 1
DanPatterson_Retired
Jake caught it, Esteban.... for future reference Code Formatting... the basics++
