Batch Re-projection script syntax error
4715
13
01-21-2015 10:32 AM
SalmanAhmed
I have started learning Python for ArcGIS last week and have a simple script to reproject all the datasets in a folder. The script says "syntax error- invalid syntax" but I can't find anything. Can someone please have a look? It seems something very basic but I'm pretty new so I don't see it at the moment. Also running this in ArcGIS prints "failed" right away. And the files are in place in the right folders. I have already checked.
import arcpy
... sourceWorkspace = "C:\\Users\\tx8p90\\Desktop\\Lesson2"
... targetProjection = "C:\\Users\\tx8p90\\Desktop\\python excercise data\\Lesson1\\contourlines.shp"
... listDataSet = arcpy.ListDatasets(sourceWorkspace)
... try:
...     for x in listDataset:
...         outputDataset = sourceWorkspace + "\\projected_" + x
...         arcpy.Project_management(x, outputDataset, targetProjection)
...         print "Reprojection successful"
... except:
...     print arcpy.GetMessages()
...     print "failed"
SusanJones
Occasional Contributor II
HiSalman
First, Try setting your workspace  before using the arcpy.ListDatasets()
eg,
arcpy.env.workspace = sourceWorkspace
Second, use the correct  arcpy.ListDatasets() arguements (wild card naming and feature type
eg,
listDataSet = arcpy.ListDatasets(wild_card = "*", feature_type = "Feature")
Susan
SalmanAhmed
Hi
I actually tried setting up the workspace already although I think its not necessary as long as you give a path in the ListDataset() function. Anyways even doing that hasn't made any difference. I get the same syntax error.
Regarding the arguments, since I need to change projection for all the files in that folder irrespective of feature type, I don't need to set any arguments like starting letter or feature type. Is that not so?
Salman
SusanJones
Hi Salman
The arcpy.ListDataset() is calling for a wildcard.
Not sure if it is optional, but it wouldn't hurt to specifiy the wildcard ("*")
See if it works
Susan
SusanJones
Hi again
Also, I don't think arcpy.ListDataset() is expecting a workspace.
Perhaps, spectify the workspace before hand under the arcpy.env.workspace parameter.
Susan
SalmanAhmed
SusanJones
Hi Salman
First, What is the value of outputDataset?
Second, Output_Coordinate_System is expecting either a projection file (with a prj extension) or a coordinate system object. Not a shp extension.
Make sure the Shapefile has a projection, and then set the targetProjection to point to it's prj file.
Susan
SalmanAhmed
replacing the shape file with the prj file doesn't change anything. Same syntax error. And I thought it was enough to just point to the shape file to get its projection.
SalmanAhmed
Ah! sorry I just realized I can't put a path in that function's argument. Ok but anyways the setting up workspace option is not working either.
import arcpy
... arcpy.env.workspace = sourceWorkspace
... listDataSet = arcpy.ListDatasets()
... try:
... except:
...     print "failed"
What could be the problem then?
SusanJones
Hi Salman
Please test the following:
tmpDir = "D:\\Tmp" ##tmpDir = r"d:\Tmp"
arcpy.env.workspace = tmpDir
print arcpy.env.workspace
ld = arcpy.ListDatasets("*")
print ld
What is returned in the ld variable ?
Susan
