I'm trying to get an old python script from 10.1 days to run in ArcGISPro 3. I ran it through 2to3 and while it runs, it emits useless warnings (File cannot be processed) for each layer and has blank output after the layer name. I'm hoping to a) get help getting it to run in its fully glory (maybe switching in some newer functions) and/or b) figure out how to get more informative errors. I just started using ArcGIS Pro and chose to use Notebook until I can figure out running from an IDE.
PS, I thought it might be some outdated metadata, but I created a new layer in ArcGISPro and it still shows the same warnings. So far it's ran on Shapefiles, FileGDB vectors, and .tifs. Same problems.
Here's the top 10% of it.
# Version: ArcGIS 10.1 and 10.2
# Purpose: This script will iterate through each GIS file in a folder (and all recursive folders) and report information
# about each layers metadata. The script is intended to run from a script tool inside an ArcGIS Toolbox. The script requires three
# user input values:
# 1. An input folder
# 2. An output Excel File
# 3. An output folder to store temporary files
# Revised: John Zastrow, November 18, 2022, porting to work with Python 3 and ArcGIS Pro 3.0
try:
# Setup environment and import modules
import xlwt, os, arcpy
from xml.etree.ElementTree import ElementTree
from xml.etree.ElementTree import Element, SubElement
arcpy.env.overwriteOutput = True
# Get user input parameters, please note that the inputFolder cannot contain any GIS files, or they will not be read
# inputFolder = arcpy.GetParameterAsText(0)
# outputFile = arcpy.GetParameterAsText(1)
# tempOutputFolder = arcpy.GetParameterAsText(2)
# Input parameters below are for testing only
inputFolder = r"C:\data\workingData\dataMiner\subfolder"
outputFile = r"C:\dataMiner\version_2.0\output\output.xls"
tempOutputFolder = r"C:\dataMiner\version_2.0\temp"
# Create workbook with one sheet named Output
wb = xlwt.Workbook()
ws = wb.add_sheet("Output")
# Create list of column names in the workbook
headerNamesList = [
"ID",
"Feature Name",
"Feature Path",
"Feature Type",
"Object Type",
"Feature Count",
"Title",
"Keywords",
"Abstract",
"Purpose",
"Contact",
"Distribution",
"Coordinate System Type",
"Geographic Coordinate System",
"Projected Coordinate System",
"Horizontal Units",
"North Bounding Coordinate",
"East Bounding Coordinate",
"South Bounding Coordinate",
"West Bounding Coordinate",
"Created Date",
"Modified Date",
"MetaData Version",
headerColumn = 0
for name in headerNamesList:
ws.write(0, headerColumn, name)
headerColumn = headerColumn + 1
# Create empty global lists and other global variables
datasetList = []
fcList = []
tableList = []
workspaceList = []
rasterList = []
listOfEnvWorkspaces = []
excelRow = 1
# Fucntion to test if metadata tags have values in XML file
def verifyMetadata(tag
global tagReturn
if tag is not None:
tagReturn = tag.text
return tagReturn
else:
tagReturn = "METADATA VALUE IS EMPTY"
return tagReturn
# Searches through all folders for GIS files
for dir, folderNames, fileNames in os.walk(inputFolder
listOfEnvWorkspaces.append(dir)
for subFolderName in listOfEnvWorkspaces:
arcpy.env.workspace = subFolderName
print("Processing Folder: " + subFolderName)
arcpy.AddMessage("Processing Folder: " + subFolderName)
datasetList = arcpy.ListDatasets()
fcList = arcpy.ListFeatureClasses()
tableList = arcpy.ListTables()
workspaceList = arcpy.ListWorkspaces("", "Access")
rasterList = arcpy.ListRasters()
# Checks for feature classes in file geodatabases feature classes, coverages, and CAD files
for dataset in datasetList:
for fc in arcpy.ListFeatureClasses("", "", dataset
try:
# Creates a temporary empty XML file to store each files XML data
fcXML = tempOutputFolder + "/" + fc + ".xml"
tempXMLFile = open(fcXML, "w")
tempXMLFile.write("<metadata>\n")
tempXMLFile.write("</metadata>\n")
tempXMLFile.close()
# Copies metadata from file into temporary XML file
arcpy.MetadataImporter_conversion(fc, fcXML)
# Makes an ElementTree object and reads XML into ElementTree
tree = ElementTree()
tree.parse(fcXML)
# Checks on XML version (9.x vs. 10.x) and gathers information on metadata
if tree.find("Esri/ArcGISFormat") is not None:
print(
" Processing File: "
+ os.path.join(dataset, fc)
+ " (Version 10.x XML)"
arcpy.AddMessage(
title = tree.find("dataIdInfo/idCitation/resTitle")
keywords = tree.find("dataIdInfo/searchKeys/keyword")
abstract = tree.find("dataIdInfo/idAbs")
purpose = tree.find("dataIdInfo/idPurp")
contact = tree.find("mdContact/rpIndName")
distribution = tree.find("distInfo/distFormat/formatName")
fcMetaDataVersion = "10.x"
else:
print(
+ " (Version 9.x XML)"
arcpy.AddMessage(
title = tree.find("idinfo/citation/citeinfo/title")
keywords = tree.find("idinfo/keywords/theme/themekey")
abstract = tree.find("idinfo/descript/abstract")
purpose = tree.find("idinfo/descript/purpose")
contact = tree.find("idinfo/ptcontac/cntinfo/cntperp/cntper")
distribution = tree.find("distinfo/resdesc")
fcMetaDataVersion = "9.x"
created = tree.find("Esri/CreaDate")
modified = tree.find("Esri/ModDate")
