Hi, I try to use the calculator field to update a field that store lengths in a shapefile; I do this because I try to put the task in model builder. I use python under suggestion of what I read in the help and the syntax I read for this task is as follow:
!shape.length@kilometers!
I fill the text box of the field calculator with this line of code, but it`s return a syntax error.
Someone knows what it´s wrong ? I work under Windows XP, ArcGis 10, ArcEditor evaluation version.
Virginia
