calculate mean of selected raster chosen from multiple raster using ArcPy
5345
52
08-24-2016 11:15 AM
ShouvikJha
Occasional Contributor III
I am trying to  calculate mean of selected raster chosen from multiple raster. I have multiple raster file in different month folder, i am trying to select only two raster (e.g For JANUARY : 001_Max_Temper.tif, 001_Min_Temper.tif) from different month folder (JANUARY, FEBRUARY....DECEMBER) and calculate the mean of those selected raster and save it as on same month folder (e.g output name, JANUARY: 001_Mean_Temp).
I have written a code to do this task but i am getting error massage while i am running this code. Below i have attached my code.
import arcpy, os, calendar
from arcpy import env
from arcpy.sa import *
arcpy.CheckOutExtension("Spatial")
arcpy.env.parallelProcessingFactor = "100%"
topWorkspace = r'D:\SWAT-WEATHER-DATA2'
arcpy.env.workspace = topWorkspace
# Get dict of months and month-number (i.e. January = 001, March = 003 etc.)
months = {calendar.month_name[i].upper(): str(i).zfill(3) for i in range(1, 13)} # Get dict of months and month number (i.e. January = 001, March = 003 etc.)
# Step through list of all folders
for folderPath in arcpy.ListWorkspaces():
    baseName = os.path.basename(folderPath).upper()
    if baseName in months: # Test that subfolder is a month name
        monthNumber = months[baseName] # Get month-number for use in output filename
        arcpy.env.workspace = folderPath
        rasterList = arcpy.ListRasters('*Max_Temper.tif', '*Min_Temper.tif')
        # Execute CellStatistics
        outCellStatistics = CellStatistics(rasterList, "MEAN", "NODATA")
        #Save the output
        outRasterName = outCellStatistics, "Mean_Temp_{}.tif".format(monthNumber)
        outCellStatistics.save(outRasterName)
#print done
print 'done'
ShouvikJha
Xander Bakker‌. The expected output for month of October  is 1 and we got the same. Through this calculation i am going to do research on  monthly  temperature effect on vegetation productivity, In India month of October is peak period for vegetation growth therefore October month temperature considering as a  optimum temperature (ras_oct)  for vegetation growth and its keep constant for all month's calculation.
If Temperature more or less from Optimum Temperature than productivity of vegetation also less therefore we kept constant the October month temperature.
Month of October the final output of TScalar is 1 and except October month TScalar vary between 0 to 1 because temperature can't meet with optimum temperature .
I am very thankful to you for your  guidance.
XanderBakker
Esri Esteemed Contributor
Thanks for the feedback! Interesting!
ShouvikJha
Xander Bakker‌. I am taking one more step to do calculation from all those raster from different subfolder. I am trying to execute this code for the next step calculation but i am getting error, below is code. Please cooperate me. The error code also attached
Message File Name Line Position
Traceback
 <module> <module2> 53
 main <module2> 32
UnboundLocalError: local variable 'ras_APAR' referenced before assignment
def main():
 import arcpy
 import os
 arcpy.env.overwriteOutput = True
 # Checkout extension
# Workspace Folder
 ws_in_apar = r'D:\MODIS-NDVI-2012\APAR'
 ws_in_tscalar = r'D:\MODIS-NDVI-2012\TScalar'
 ws_in_wscalar = r'D:\MODIS-NDVI-2012\WScalar'
 ws_out_NPP = r'D:\MODIS-NDVI-2012\NPP'
# list "apar" rasters (e.g r001_APAR, r002_APAR so on  )
 arcpy.env.workspace = ws_in_apar
 lst_ras_APAR = arcpy.ListRasters()
 print "lst_ras_APAR", lst_ras_APAR
# list "tscalar" rasters (e.g r001_TSCALAR, r002_TSCALAR so on )
 arcpy.env.workspace = ws_in_tscalar
 lst_ras_TScalar = arcpy.ListRasters()
 print "lst_ras_TScalar", lst_ras_TScalar
 # list "wscalar" rasters (e.g r001_WSCALAR, r002_WSCALAR so on)
 arcpy.env.workspace = ws_in_wscalar
 lst_ras_WScalar = arcpy.ListRasters()
 print "lst_ras_WScalar", lst_ras_WScalar
for ras_name in lst_ras_APAR:
 ras_APAR = arcpy.Raster(os.path.join(ws_in_apar, ras_APAR))
 print "ras_apar", ras_apar
for ras_TSCALAR in lst_ras_TSCALAR:
 ras_TSCALAR = arcpy.Raster(os.path.join(ws_in_tscalar, ras_TSCALAR))
 print "ras_TSCALAR", ras_TSCALAR
 for ras_WSCALAR in lst_ras_WSCALAR:
 ras_WSCALAR = arcpy.Raster(os.path.join(ws_in_wscalar, ras_WSCALAR))
 print "ras_WSCALAR", ras_WSCALAR
# calculate
 ras_NPP = (ras_APAR * ras_TSCALAR * ras_WSCALAR * 0.98)
#Process rectricted within mask file : Process will occur only on location that fall within the mask
 #else it will be assigned to nodata inthe output
 mask="D:\MOD-REF\NDVI\CROP-L-OCT-15.img"
 NPP_Mask = ExtractByMask(ras_NPP, mask)
 # save raster
 ras_num = ras_name[:3]
 out_name_NPP = os.path.join(ws_out_NPP, 'r{0}_NPP.TIF'.format(ras_num))
 NPP_Mask.save(out_name_NPP)
if __name__ == '__main__':
 main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
print "ras_apar", ras_apar   <<=====
 ras_APAR I suspect
ShouvikJha
I have changed that line, but still error.
XanderBakker
shouvik jha , as Dan Patterson correctly mentions keep in mind that variable names are case sensitive.
There are however as lot more things going on. I assume that for each month you want to perform the calculation of the NPP raster. If that is true, you need to look through the month numbers and construct the names for the APAR, TSCALAR and WSCALAR rasters for that month, define the complete name (including the path) for each raster and construct the raster object. Only then you can calculate the NPP raster.
Within the same loop you will have to include the NPP mask raster creation.
ShouvikJha
xander_bakker‌. Thank you. My humble request Can i get a small example of that modification
ShouvikJha
While i am running the program i am getting the print of raster file (Upto 27 line), when program execute next line then only error occurring, please give  suggestion
Printing file
lst_ras_APAR [u'r001_APAR.TIF', u'r002_APAR.TIF', u'r003_APAR.TIF', u'r004_APAR.TIF', u'r005_APAR.TIF', u'r006_APAR.TIF', u'r007_APAR.TIF', u'r008_APAR.TIF', u'r009_APAR.TIF', u'r010_APAR.TIF', u'r011_APAR.TIF', u'r012_APAR.TIF']
lst_ras_TScalar [u'r001_TSCALAR.TIF', u'r002_TSCALAR.TIF', u'r003_TSCALAR.TIF', u'r004_TSCALAR.TIF', u'r005_TSCALAR.TIF', u'r006_TSCALAR.TIF', u'r007_TSCALAR.TIF', u'r008_TSCALAR.TIF', u'r009_TSCALAR.TIF', u'r010_TSCALAR.TIF', u'r011_TSCALAR.TIF', u'r012_TSCALAR.TIF', u'T_SCALAR_001.tif', u'T_SCALAR_002.tif', u'T_SCALAR_003.tif', u'T_SCALAR_004.tif', u'T_SCALAR_005.tif', u'T_SCALAR_006.tif', u'T_SCALAR_007.tif', u'T_SCALAR_008.tif', u'T_SCALAR_009.tif', u'T_SCALAR_010.tif', u'T_SCALAR_011.tif', u'T_SCALAR_012.tif']
lst_ras_WScalar [u'r001_WSCALAR.TIF', u'r002_WSCALAR.TIF', u'r003_WSCALAR.TIF', u'r004_WSCALAR.TIF', u'r005_WSCALAR.TIF', u'r006_WSCALAR.TIF', u'r007_WSCALAR.TIF', u'r008_WSCALAR.TIF', u'r009_WSCALAR.TIF', u'r010_WSCALAR.TIF', u'r011_WSCALAR.TIF', u'r012_WSCALAR.TIF']
 File "<module2>", line 59, in <module>
 File "<module2>", line 32, in main
UnboundLocalError: local variable 'ras_apar' referenced before assignment
ShouvikJha
Xander Bakker‌. I have tried in my best and and corrected the code suggested by you and Dan Patterson‌. the code is successfully run But i am not getting the desire output from the program, the output name of NPP should be
001_NPP.TIF
but i am getting like this
rr001_WSCALAR.TIF_NPP.TIF
Please cooperation me to solve this issue . Below i attached my updated code
def main():
 import arcpy
 import os
# list "apar" rasters (e.g r001_APAR)
# list "tscalar" rasters (e.g r012_TSCALAR)
 lst_ras_TSCALAR = arcpy.ListRasters()
 print "lst_ras_TSCALAR", lst_ras_TSCALAR
 # list "wscalar" rasters (e.g r001_WSCALAR)
 lst_ras_WSCALAR = arcpy.ListRasters()
 print "lst_ras_WSCALAR", lst_ras_WSCALAR
 ras_APAR = arcpy.Raster(os.path.join(ws_in_apar, ras_name))
 print "ras_APAR", ras_APAR
for ras_name in lst_ras_TSCALAR:
 ras_TSCALAR = arcpy.Raster(os.path.join(ws_in_tscalar, ras_name))
 for ras_name in lst_ras_WSCALAR:
 ras_WSCALAR = arcpy.Raster(os.path.join(ws_in_wscalar, ras_name))
# calculate
 NPP_Mask = ExtractByMask (ras_NPP, mask)
 # save raster
 out_name_NPP = os.path.join(ws_out_NPP, 'r{0}_NPP.TIF'.format(ras_name))
XanderBakker
You could try something like this:
import arcpy
import os
def main():
    mask = "D:\MOD-REF\NDVI\CROP-L-OCT-15.img"
    for ras_num in [str(i).zfill(3) for i in range(1, 13)]:
        # get required rasters for current month number
        ras_APAR = getRasterFromList(ras_num, lst_ras_APAR, ws_in_apar)
        ras_TSCALAR = getRasterFromList(ras_num, lst_ras_TSCALAR, ws_in_tscalar)
        ras_WSCALAR = getRasterFromList(ras_num, lst_ras_WSCALAR, ws_in_wscalar)
        # verify if raster are valid
        if all([ras_APAR, ras_TSCALAR, ras_WSCALAR]):
            # calculate
            NPP_Mask = arcpy.sa.ExtractByMask (ras_NPP, mask)
            # save raster
def getRasterFromList(ras_num, lst, ws):
    ras = None
    for ras_name in lst:
        if ras_num in ras_name:
            ras = arcpy.Raster(os.path.join(ws, ras_name))
            break
    if ras is None:
        print ras_num, "not found in lst", lst
    return ras
    main()
The idea behind the code is to loop through the months and create the ras_num, then check in each raster list is there is a name that contains that ras_num (see the function getRasterFromList).
If all 3 rasters are defined the calculation is performed.
Once again, I did not test this code.
