I have a script that needs to calculate the location numbers within a page and provide the ranges in a formatted list that will be used to fill out a text field to be used with dynamic text. There are often locations missing, so the list won't be consecutive. Right now I have the code below which accomplishes that, but if there is a single non consecutive location it lists it as a range itself i.e. 5-5. Is there a way to edit the script to prevent this?
loc_numbers = [row[0] for row in arcpy.da.SearchCursor(join_lyr, "Map_ID")]
ranges = sum((list(t) for t in zip(loc_numbers, loc_numbers[1:]) if t[0]+1 != t[1]), [])
iranges = iter(loc_numbers[0:1] + ranges + loc_numbers[-1:])
range_values = ', '.join([str(n) + '-' + str(next(iranges)) for n in iranges])
