calculating the complete path to an attribute
1272
8
01-04-2013 06:42 AM
davidmetzler
Greetings,
    I have a question that I believe has a simple answer but I just can't quite find it. I am trying to calculate the absolute path of a shapefile to an attribute. so the goal is to have a "shpname" field that has the comple path e.g. C:/desktop/superfunline.shp. here is my python.
def main():
    try:
        import arcpy, sys, traceback, os, glob
        masterFolder = r"Q:\GIS\Field_Data\MT"
        outputFolder = r"C:\tmp\Shp_merged"
        #collect a list of subfolders in master folder
        arcpy.env.workspace = masterFolder
        arcpy.ListWorkspaces('','Folder')
        subfolderLst = arcpy.ListWorkspaces('','Folder')
        print subfolderLst
        for subfolder in subfolderLst:
            arcpy.env.workspace = subfolder
            fcLst = arcpy.ListFeatureClasses()
            for fc in fcLst:
                #file = fc in fcLst
                filename = os.path.abspath(__file__)
                print filename
                arcpy.AddField_management(fc, 'shpname','text')
                arcpy.CalculateField_management(fc, 'shpname',filename, "PYTHON" )
    except:
        print arcpy.GetMessages()
        # Get the traceback object  '"' + wildcard + '"'
        tb = sys.exc_info()[2]
        tbinfo = traceback.format_tb(tb)[0]
        # Concatenate information together concerning the error into a
        #   message string
        pymsg = tbinfo + "\n" + str(sys.exc_type)+ ": " + str(sys.exc_value)
        # Return python error messages for use with a script tool
        arcpy.AddError(pymsg)
        # Print Python error messages for use in Python/PythonWin
        print pymsg
if __name__ == '__main__':
    main()
I am thinking the bold is where the error is occuring. the error is:
ERROR 000539: <type 'exceptions.SyntaxError'>: invalid syntax (<expression>, line 1)
Thanks!
Dave
markdenil
Why do you use __file__ in
filename = os.path.abspath(__file__) ?
Why not
filename = os.path.abspath(fc)
I also assume that the filename variable needs to be properly quoted
before being passed to CalculateField
arcpy.CalculateField_management(fc, 'shpname', r'"%s"' % (filename), "PYTHON" )
- that is, with double quotes (required by calculate field)
surrounded by single quotes (needed to pass the double quotes as part of the string)
davidmetzler
Why not
This is returning the path to the script and the fc name. I would like the abspath of the file and the file name.
JakeSkinner
Esri Esteemed Contributor
Hi David,
Add single quotes to your 'filename' variable.  Try the following:
for fc in fcLst:
    filename = "'" + os.path.abspath(__file__) + "'"
davidmetzler
Hi David,
for fc in fcLst:
I have attempted this and when I do the path yielded is C:\Python26\ArcGIS10.0\Lib\idlelib\idle.pyw If I change __file__ to (fc) I get the return of P:\Scripts\scratch\CheckShot.shp' with P:\Scripts\scratch being the path to the script not the shapefile. Any thoughts?
Thanks!
Dave
JakeSkinner
If you're looking to obtain the path of the feature class,  try:
filename = "'" + arcpy.env.workspace + os.sep + fc + "'"
BruceNielsen
I've always used the CatalogPath property of a FeatureClass or Layer's Describe object.
davidmetzler
We have a solution! Here is the code:
import  arcpy
from arcpy import env
import os
import time
def main():
    try:
        import arcpy, sys, traceback, os, glob, shutil
        log = r'Q:\1-EMPLOYEE INBOX\David\downloads\logSurveyData.txt'
        dst = r'Q:\GIS\Field_Data\z_archive\PMM'
        #shutil.copytree(masterFolder, dst + time.strftime('%m_%d_%y'))
        print subfolderLst
            for fc in fcLst:
                #file = fc in fcLst
                print filename
                arcpy.CalculateField_management(fc, 'shpname', filename, "PYTHON" )
    except:
# message string
        print pymsg
    main()
Big thanks to JSkinn3
curtvprice
I agree with Bruce -- the last one will work even if the workspace is not set.
1. arcpy.env.workspace + os.sep + fc
2. os.path.join(arcpy.env.workspace,fc)
3. arcpy.Describe(fc).catalogPath
