Can you run a BAT (Batch) file using ArcPy?
1186
9
01-04-2023 08:00 AM
CMcDonald
Occasional Contributor II
is it possible to run a bat file using the version of Python (ArcPy) supplied with ArcGIS Pro 2.9 or ArcMap 10.8?
Thank you
BlakeTerhune
MVP Regular Contributor
You wouldn't use arcpy, you would use the subprocess module built into Python.
https://stackoverflow.com/a/5469427
CMcDonald
Can regular Python from https://www.python.org  be installed also when my server already has a "Python27" folder setup as Arcmap 10.8 is installed on this machine already.
BlakeTerhune
Installing ArcGIS (ArcMap or Pro) includes a full install of Python (2.x for ArcMap, 3.x for Pro). There's no need to install Python if you've already installed ArcGIS.
Brian_Wilson
You can run any program at all that you have permission to run on the computer. Here is a quick example.
https://datatofish.com/batch-file-from-python/
MichaelVolz
Esteemed Contributor
Are you trying to access python modules that are not installed by default during the installation of ArcMap or Pro?
Is this for the eventual goal of running a Windows Scheduled Task on a regular interval?
CMcDonald
I would rather access python installed by ArcMap 10.8 if possible so that no additional software is required.
It won't be to run a Scheduled Task, the BAT I'm creating ultimately will trigger and FME Workspace to run but it has to be run on demand by the user as and when required.
forestknutsen1
Can you just have the user run the bat file from there desktops? Is the FME workspace and environment going to be on a server?
CMcDonald
Yes I think you are right, I have been having a similar thought myself.  Ultimately I will need to create a Python script, an ESRI Tool, a Geoprocessing Task and then add that to a WAB just to allow a nicer interface for the users.
I could probably just put the BAT file on a shared folder on the server and add permissions so they can run the FME workspace on the server.
forestknutsen1
Example of sub process use:
import argparse
import os
import subprocess
parser = argparse.ArgumentParser(description='initialize electric trace weights')
parser.add_argument('--env', help='target environment: dev, test , or prod', default='dev')
args = parser.parse_args()
env = args.env
database = {'dev': 'dev', 'test': 'test', 'prod': 'prod'}[env]
working_dir = os.path.dirname(os.path.realpath(__file__))
password = xxxx
trace_weight_exe = os.path.join(working_dir, 'ElectricTraceWeightInit.exe')
command = '"{exe}" {db} {pw}'.format(exe=trace_weight_exe, db=database, pw=password)
process = subprocess.Popen(command, shell=True, stdin=subprocess.PIPE, stdout=subprocess.PIPE,
						   stderr=subprocess.PIPE)
exit_code = process.wait()
