Can you update query layer connection properties with Python like you can update SDE connection properties?
5336
04-08-2015 01:19 PM
MichaelVolz
Esteemed Contributor
I have been using SDE connections for many years and everytime the Oracle Database gets upgraded I need to programmatically change all the SDE connections in the mxds using python scritping.
My organization is now moving towards query layers and I would like know if the same type of update can be done with the query layer connections using python scripting.  If this does exist, where would I find sample code?
MichaelVolz
Samuel:
Can I at least use python to get the current query layer's properties that I would use to create a replica of the current query layer that would have updated database connection properties (e.g. a newer version of Oracle)?
SamuelTompsett
Occasional Contributor II
Michael,
After looking into this a little more, I stand corrected. You might be able to change the data source  for the query layer using the arcpy.mapping.layer. You should be able to use findandreplaceWorkspacepath. I havent tried this, but it should be possible given the webhelp.
The webhelp for arcpy.mapping is below:
ArcGIS Help 10.1
ChristianWells
Hi Michael,
It is possible to do this using arcpy.mapping.Layer():
import arcpy
mxd = arcpy.mapping.MapDocument(<mxdFile>)
lyr = arcpy.mapping.Layer(<queryLayer>)
oldConn = lyr.workspacePath
lyr.findAndReplaceWorkspacePath(<newSDEconn>, <oldSDEconn>)
mxd.save()
Just a note, you won't be able to use the replaceDataSource method for query layers because the dataSource property does not return the name of the tables used in the query layer.
print lyr.dataSource
output = u'Database Connections\\ConnectionFile.sde\\SDE.%queryLayer'
VivianMurga
Hi do you have more info on this topic?
