Cannot delete version created with python tool
6553
13
02-19-2015 11:41 AM
MatthewLueders
I am having an issue where I cannot delete a version because it is said to still be in use, but this error only arises when I use the script from an ArcGIS Tool in the Toolbox.  When I run the script from an outside IDE, or even the same commands from the python window, it finishes without error.
The general process is:
1) create a new version "Child"
2) Loop of feature classes:
    2.1) create feature layer
    2.2) change to version "Child"
    2.3) various queries etc
    2.4) copy feature layer
    2.5) change to version Default
3) run arcpy.ClearWorkspaceCache_management()  [updated]
4) delete version "Child" --- arcpy.DeleteVersion_management(sde_database, "username".Child)
The error returned by the tool dialogue is:
Executing: DeleteVersion "/path/connectionfile.sde" "username".Child
Start Time: Thu Feb 19 13:12:24 2015
ERROR 999999: Error executing function.
The version is currently in use. ["username".Child]
Failed to execute (DeleteVersion).
At this point I will go to the Version Manager to delete the Child version manually and I get the following error:
Could not delete version "username".Child.
[An event was unable to invoke any of the subscribers (Exception from
HResult: 0x80040201)]
If I close and reopen ArcMap I can then delete the version. Does anyone have an idea what might be causing this and how to resolve it?
MatthewLueders
It's a public version.  I just can't connect to it from a stand-alone script.  That's another approach to resolving this, I guess, if I didn't need the additional version.  I just haven't been able to find a way to connect to that version directly. Specifying the other "Username.version" doesn't work.
MatthewLueders
I missed one of your questions:
Oh, so the version you make is created under another version that has changes you want to see?
Yes
Were you using arcpy.ChangeVersion_management() to change versions?
Yes
Can the changes in the parent version be posted up so you can just do the script work on Default?
No
MatthewLueders
Reconciling didn't seem to help.  Good thought though.
MattFrancis
I am stuck in the same spot.  Did you figure out what was holding the connection open?
