Change text to Unicode
8017
02-01-2012 09:52 PM
chriss_
New Contributor II
Hi!
Here is my problem. I have a bulk of attribute tables with string columns. Those string columns contain text that has been written in Vietnamese font (.vn arial, VNI Windows, VIQR and others). Mostly each attribute table contains only one Font. So now if i open a map it looks like that "di??n tÝch, d©n sè c¸c ®¬n v?? hµnh chÝnh cña thµnh phè" instead of "di??n tích, dân s?? các ???n v?? hành chính c?a". All this different fonts are a big mess and people who didn't install the fonts can not read it. To keep it short the best way is to bring it all to unicode which I d like to do in Python.
What I am thinking about is:
1) Step through the attribute table
2) Read the field value (original Text)
3) Convert it to Unicode (This I don't know how to)
4) Update the field with the Converted text
and so on
Anybody out there who can give me a hand on this? Or any other time saving solutions?
Best regards
Chris
P.S. For few files i used to do it as follows:
1) Export the attribute table as a .dbf file
2) Open it in Excel and copy the whole table into clipboard
3) Open a program called UniKey
4) Pressing ctrl+shift+f6  - which converts the text in the clipboard to unicode (u have to define the source and output dataset first)
5) Paste it over the orig dbf table
6) In Arcgis join it with the original table
7) Use the field calculator to copy the joined table to the original one
It is obviously why i don't want to do that hundred of times.
AndrewChapkowski
You can use the encode() on your string:
>>> a =  u"di�?n tÝch, d©n sè c¸c ®¬n v�? hµnh chÝnh cña thµnh phè"
>>> print a.encode('ascii','ignore')
din tch, dn s cc n v hnh chnh ca thnh ph
or
>>> print a.encode('ascii','replace')
di?n t?ch, d?n s? c?c ??n v? h?nh ch?nh c?a th?nh ph?
or even:
>>> print a.encode('ascii', 'xmlcharrefreplace')
You can also convert the string to base64:
>>> a = a.encode('base64')
>>> print a
ZGnDlm4gdMOdY2gsIGTCqW4gc8OoIGPCuGMgwq7CrG4gdsOeIGjCtW5oIGNow51uaCBjw7FhIHRo
wrVuaCBwaMOo
>>> print a.decode('base64')
Hope this helps.
Here are some links that will give you some background information:
http://docs.python.org/library/codecs.html
http://docs.python.org/howto/unicode.html
chriss_
New Contributor II
Hi andrew!
Thanks for your reply. Unfortunately the commands you sent me do not solve my problem. Vietnamese Script is a kind of awkward coded. So I am not sure if there is a built in solution for this. I just found the following link descriping vn character sets. http://vietunicode.sourceforge.net/
Most important for me is the TCVN3.
So I could do a dictionary and look up every single character and replace it by the corresponding unicode character. However from my feeling I would say that this would slow down my code dramatically and doesn't look like the brightest solution. Besdides I don't know how to step through the characters as some TCVN3 character sets have one other two characters to symbolize 1 unicode character (e.g.â =© but  �? = Aµ).
Any suggestions?
I also came across an old script dealing with a similar problem in 9.3. but though i modified it I can not get it to run in arcgis10. I keep getting an error stating 'Result' object has no attribute 'GetOutput'
# Simple script for conversion of Vietnamese encoding
import arcpy
from arcpy import env
import os
import string
import csv
arcpy.env.overwriteOutput = True
def Convert(str,s,d):
    global _Unicode, _TCVN3, _KhongDau
    result = u''
    for c in str:
        idx = s.find(c)
        if idx >= 0:
            c = d[idx]
        result += c
    return result
# Array of characters (Using Tuple instead of List)
_Unicode = (
    #'�??�??�?�?�??�??�??�?ª�?Š�??�??�??�??�??�??'
    u'â�?�?�?�?Đê�?ô�?ơƠưƯ'
    #u'\xe2\xc2\u0103\u0102\u0111\u0110\xea\xca\xf4\xd4\u01a1\u01a0\u01b0\u01af'
    #'�??�??�??�??áº?áº?�??�?�?áº?áº?áº?áº?áº?áº?áº?áº?áº?Ẫáº?áº?áº?áº?áº?áº?áº?áº?ẵáº?áº?áº?'
    u'áÁà�?ảẢã�?ạẠấẤầẦẩẨẫẪậẬắẮằẰẳẲẵẴặẶ'
    #u'\xe1\xc1\xe0\xc0\u1ea3\u1ea2\xe3\xc3\u1ea1\u1ea0\u1ea5\u1ea4\u1ea7\u1ea6\u1ea9\u1ea8\u1eab\u1eaa\u1ead\u1eac\u1eaf\u1eae\u1eb1\u1eb0\u1eb3\u1eb2\u1eb5\u1eb4\u1eb7\u1eb6'
    #'�??�??�??�??áº?Ẻáº?áº?áº?áº?áº?áº?á??á??á?�?á??á??á??á??á??�??�??�??�?�?á??á??�??�??á??á?Š'
    u'é�?è�?ẻẺẽẼẹẸếẾề�?�?�?�?�?�?�?íÍì�?�?�?ĩĨ�?�?'
    #u'\xe9\xc9\xe8\xc8\u1ebb\u1eba\u1ebd\u1ebc\u1eb9\u1eb8\u1ebf\u1ebe\u1ec1\u1ec0\u1ec3\u1ec2\u1ec5\u1ec4\u1ec7\u1ec6\xed\xcd\xec\xcc\u1ec9\u1ec8\u0129\u0128\u1ecb\u1eca'
    #'�??�??�??�??á??á?Ž�?µ�??á??á?�?á??á??á??á??á??á??á??á??á??á??á??á?šá??á?�?á?Ÿá?žá??á??á??á??'
    u'ó�?ò�?ỏ�?õ�?ọ�?�?Ố�?�?�?�?�?�?�?�?�?�?ờ�?�?�?ỡỠợỢ'
    #u'\xf3\xd3\xf2\xd2\u1ecf\u1ece\xf5\xd5\u1ecd\u1ecc\u1ed1\u1ed0\u1ed3\u1ed2\u1ed5\u1ed4\u1ed7\u1ed6\u1ed9\u1ed8\u1edb\u1eda\u1edd\u1edc\u1edf\u1ede\u1ee1\u1ee0\u1ee3\u1ee2'
    #'�?º�?š�??�??á??á??�??�??á??á??á??á??á??á?ªá??á??á??á??á??á??á??á??á??á??á??á??á?µá??�??�??'
    u'ú�?ù�?ủỦũŨụỤứỨừỪửỬữỮựỰỳỲỷỶỹỸỵỴýÝ'
    #u'\xfa\xda\xf9\xd9\u1ee7\u1ee6\u0169\u0168\u1ee5\u1ee4\u1ee9\u1ee8\u1eeb\u1eea\u1eed\u1eec\u1eef\u1eee\u1ef1\u1ef0\u1ef3\u1ef2\u1ef7\u1ef6\u1ef9\u1ef8\u1ef5\u1ef4\xfd\xdd'
_KhongDau = (
    u'aAaAdDeEoOoOuU'
    u'aAaAaAaAaAaAaAaAaAaAaAaAaAaAaA'
    u'eEeEeEeEeEeEeEeEeEeEiIiIiIiIiI'
    u'oOoOoOoOoOoOoOoOoOoOoOoOoOoOoO'
    u'uUuUuUuUuUuUuUuUuUuUyYyYyYyYyY'
_TCVN3= (
  #'�??�??�??�??�??�??�?ª�??�??�??�??�??�??�??'
    u'©¢¨¡®§ª£«¤¬¥*¦'
    #'\xa9\xa2\xa8\xa1\xae\xa7\xaa\xa3\xab\xa4\xac\xa5\xad\xa6'
    #'�??�??�?µ�?µ�??�??�??�??�??�??�?Š�?Š�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??'
    u'¸¸µµ¶¶··¹¹�?�?�?�?�?�?�?�?�?�?¾¾»»¼¼½½�?�?'
    #'\xb8\xb8\xb5\xb5\xb6\xb6\xb7\xb7\xb9\xb9\xca\xca\xc7\xc7\xc8\xc8\xc9\xc9\xcb\xcb\xbe\xbe\xbb\xbb\xbc\xbc\xbd\xbd\xc6\xc6'
    #'�??�??�?�?�?�?�?Ž�?Ž�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�?�?�?�?�?ž�?ž'
    u'ÐÐ�?�?�?�?ÏÏ�?�?�?�?�?�?�?�?�?�?�?�?ÝÝ�?�?�?�?�?�?�?�?'
    #u'\xcf\xcf\xd1\xd1\xd5\xd5\xd2\xd2\xd3\xd3\xd4\xd4\xd6\xd6\xdd\xdd\xd7\xd7\xd8\xd8\xdc\xdc\xde\xde'
    #'�??�??�?Ÿ�?Ÿ�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�??�?ª�?ª�??�??�??�??�??�??'
    u'ãã�?�?ááââääèèååææççééííêêëëììîî'
    #'\xe2\xe2\xe4\xe4\xe8\xe8\xe5\xe5\xe6\xe6\xe7\xe7\xe9\xe9\xed\xed\xea\xea\xeb\xeb\xec\xec\xee\xee'
    #'�??�??�??�??�??�??�??�??�??�??�??�??�?µ�?µ�??�??�??�??�??�??�?º�?º�??�??�??�??�??�??�??�??'
    u'óóïïññòòôôøøõõöö÷÷ùùúúûûüüþþýý'
    #'\xf3\xf3\xef\xef\xf1\xf1\xf2\xf2\xf4\xf4\xf8\xf8\xf5\xf5\xf6\xf6\xf7\xf7\xf9\xf9\xfa\xfa\xfb\xfb\xfc\xfc\xfe\xfe\xfd\xfd'
def ConvertEncoding(input_fc,input_fd,newfd,sE,dE):
    global arcpy
    rows = arcpy.UpdateCursor(input_fc)
    result = arcpy.GetCount_management(input_fc)
    count = int(result.GetOutput(0))
    arcpy.SetProgressor("step", "Reading", 0, count, 1)
    for row in iter(rows.next, None):
        string1 = row.GetValue(input_fd)
        if  string1.strip() <> "":
            newvalue =  Convert(row.GetValue(input_fd),sE,dE)
            row.SetValue(newfd,newvalue)
            rows.UpdateRow(row          )
        else:
            row.SetValue(newfd,"")
            rows.UpdateRow(row)
        arcpy.SetProgressorPosition()
    arcpy.ResetProgressor()
    del rows
    del row
#Input paramaters
inputShapefile ="C://Project/TCVN.shp" #arcpy.GetParameterAsText(0)
inputFields = "TCVN"
outputShapefile = "C://Project/UNI.shp"#arcpy.GetParameterAsText(2)
#Processing block
#Copy to new shapefile
arcpy.CopyFeatures_management(inputShapefile, outputShapefile)
# Add new field for storing result
#gp.AddField(outputShapefile,newField,"TEXT","#","#",254)#,"#","NON_NULLABLE","NON_REQUIRED","#")
#Processing conversion of encoding
inputFL = inputFields.split(";")
for inputField in inputFL:
    ConvertEncoding(outputShapefile,inputField,inputField,_TCVN3,_Unicode)
arcpy.AddMessage("Finish!")
that is the original one
import arcgisscripting
gp = arcgisscripting.create(9.3)
    result = u''
    for c in str:
        idx = s.find(c)
        if idx >= 0:
            c = d[idx]
        result += c
    return result
_Unicode = (
_KhongDau = (
    u'aAaAdDeEoOoOuU'
_TCVN3= (
    u'©¢¨¡®§ª£«¤¬¥*¦'
    global gp
    rows = gp.updatecursor(input_fc)
    result = gp.GetCount_management(input_fc)
    gp.SetProgressor("step", "Reading", 0, count, 1)
            rows.UpdateRow(row)
        else:
            rows.UpdateRow(row)
        gp.SetProgressorPosition()
    gp.ResetProgressor()
    del rows
    del row
#Input paramaters
inputShapefile = gp.GetParameterAsText(0)
inputFields = gp.GetParameterAsText(1)
outputShapefile = gp.GetParameterAsText(2)
#Processing block
gp.toolbox = "management"
try:
    gp.CopyFeatures_management(inputShapefile,outputShapefile)
    gp.AddMessage("Finish!")
#Free resources
except:
    gp.GetMessage(2)
del gp
Thanks a lot for your help
cheers
chris
MRC
New Contributor III
Bạn ơi có thể hướng dẫn mình cách sử dụng đoạn code này không mình bị lỗi font chữ trong arcgis nhưng fixx không được
MattCohen-Price
flederfauz,
Same problem here: a list of neighborhood names stored in a Gujarati font that I want to store in a geodatabase with unicode.
I wish I had a real solution for you within python. I ended up taking my data out of ArcGIS and use a character translator I found for Microsoft Word specifically for Hindi and Gujarati fonts. The translator is built into a Microsoft Word ribbon and installed via a replication of the default Word template. The translation itself is performed by character-by-character replacement.
Of course, a Gujarati translator isn't going to help you, but it's an indicator that character-by-character replacement might be required, as you suggested.
I too would be interested in a functional python-based solution to this problem.
LeThanh
New Contributor II
@flederfauz:
The script can run on ArcGIS 10 without problems, and i have update some minor changes for conversion facility. You can run it directly under either ArcCatalog or ArcMap.
