Hello all,
I recently cloned the default ArcGIS Pro 2.8 Conda environment so I can install and use rasterio and dask for some big data analyses. I used the Python Command Prompt (PCP) that comes with ArcGIS to perform the clone instead of the in-software interface.
The clone worked fine, and rasterio and dask installed without issues. However, when I try to run any rasterio method that wraps GDAL I get an GDAL environment issue. I don't have any GDAL issues when using the default environment.
I activated the the cloned environment in the PCP to have a look, and get this warning:
Does anyone know how to make sure my cloned environment is directed to the correct GDAL path?
Many thanks!
