manual selection won't happen. If you wanted to do this in arcmap or pro, you would have to use two tools in a toolbox, the first generating the output and the second doing the selection.
Alternately, if they knew what they wanted to select ahead of time, it could be specified as a query (select by attributes) which would follow the creation of the outputs.
There are options to do interactive sessions in Pro but they are more geared to creating a geometry object to use as input to a tool (ie create a point, then run a Near analysis from the created point and another geometry file)
