Concatenate iterating variable with string in For loop
5818
10
11-23-2015 04:41 PM
EdwardGlover
I summarize rows in a table in the SearchCursor and store them as variables.  I want to refer to these variables in the following update cursor to write to a table.  I get the following error on the second last line of code (in red): Tuple object does not support item assignment.  When I debug the code, ROW[0] equals 'ARSSPAN' as a string.  I want ROW[0] to reference the integer ARSSPAN summarized in the search cursor above.  In the next iteration of the UpdateCursor, I want the integer STSPAN to be written out, etc.  I feel my issue is with assembling a variable reference through concatenating a string with the iterator.  Any assistance would be greatly appreciated.
    # Create the search cursor to iterate through table and sum spans and cost
    with arcpy.da.SearchCursor(fcdtest, ("FeedClass","SHAPE_Length","MGMTCOST",)) as cursor:
        for row in cursor:
            if row[0] == "ARS":
                ARSSPAN += row[1]/55
                ARSCOST += row[2]
            elif row[0] == "ST":
                STSPAN += row[1]/55
                STCOST += row[2]
            elif row[0] == "S":
                SSPAN += row[1]/55
                SCOST += row[2]
            elif row[0] == "ARU":
                ARUSPAN += row[1]/55
                ARUCOST += row[2]
            elif row[0] == "UT":
                UTSPAN += row[1]/55
                UTCOST += row[2]
            elif row[0] == "U":
                USPAN += row[1]/55
                UCOST += row[2]
    fld = "YR2015"
    feedcls = ["ARS","ST","S","ARU","UT","U"]
    for cls in feedcls:
        with arcpy.da.UpdateCursor(out_data, (fld,)) as cursor:
            row[0] = cls + 'SPAN'
             cursor.updateRow(row)
EdwardGlover
Thank you for stating the risks of using eval and providing me with an excellent solution.  Your insight is very much appreciated.  I would like to get your opinion on the getattr function.  Could it be used as an alternative to eval?  If so, does it represent a security risk?
