Hi all, I am new to Python and trying to make an older piece of code work. It takes two tables, compares them, and if data in table A doesn't match table B it overwrites A with B.
If they are equal it leaves them alone...
dim intval
if [STR_NUM] = [SITUS_NR] then
intval = " "
else
intval = [STR_NUM]
end if
If it finds a "nil" in a field in table B it clears the field in table A
dim intval
if [STR_NUM] = "nil" then
intval = " "
else
intval = [SITUS_NR]
end if
Finally it overwrites table A if it finds data in table B
dim intval
if [STR_NUM] <> " " and [STR_NUM] <> "nil" then
intval = [STR_NUM]
else
intval = [SITUS_NR]
end if
Can anyone help me convert these or at least one to Python?
Thank you!
