I have the following script - it creates lines from two points feature classes, Both point feature classes have a field
# that identifies the center point ID to relate them.
I would like to modify this script so I can I get all the fields from the related points relfc to spiderfc
import arcpy
cenfc = r"\\GIS\starburst.gdb\CenterPoints"
cenfld = "SiteID"
relfc = r"\\GIS\starburst.gdb\EV102218" " copy all fields from here
relfld = "USER_SiteID"
spiderfc = r"\\GIS\starburst.gdb\Spider"
print "Reading in center point IDs and coordinates..."
cendict = {}
for row in arcpy.da.SearchCursor(cenfc, [cenfld, "SHAPE@XY"]):
cendict[row[0]] = row[1]
print "Reading in related point IDs and coordinates..."
linelist = []
for row in arcpy.da.SearchCursor(relfc, [relfld, "SHAPE@XY"]):
relxy = row[1]
cenxy = cendict[row[0]]
polyline = arcpy.Polyline(arcpy.Array([arcpy.Point(cenxy[0], cenxy[1]), arcpy.Point(relxy[0], relxy[1])]))
linelist.append([row[0], polyline])
print "Setting up line feature for spider lines..."
sr = arcpy.Describe(cenfc).spatialReference
tempfc = "in_memory/tempfc"
arcpy.CreateFeatureclass_management(tempfc.split("/")[0], tempfc.split("/")[1], "POLYLINE", "", "", "", sr)
field = arcpy.ListFields(cenfc, cenfld)
fielddict = {"SmallInteger": "SHORT", "Integer": "LONG", "Single": "FLOAT", "Double": "DOUBLE", "String": "TEXT", "Date": "DATE", "BLOB": "BLOB"}
fieldtype = fielddict.get(field[0].type)
if fieldtype == "TEXT":
arcpy.AddField_management(tempfc, cenfld, fieldtype, "", "", str(field[0].length))
else:
arcpy.AddField_management(tempfc, cenfld, fieldtype, "", "", "", "", "NULLABLE")
print "Adding spider lines..."
cursor = arcpy.da.InsertCursor(tempfc, [cenfld, "SHAPE@"])
for line in linelist:
cursor.insertRow(line)
del cursor
print "Saving spider lines..."
arcpy.CopyFeatures_management(tempfc, spiderfc)
arcpy.Delete_management(tempfc)
print "All done!"
Many thanks
