Creating a City Select and Zoom tool using arcpy
2773
7
05-02-2016 10:03 AM
GarrettPullis
New Contributor II
Working on creating a lab which will allow me to type in a city name into a parameter and it will select that city, add it to the TOC and zoom into it. I'm having trouble getting around certain errors. Please help!
import arcpy
from arcpy import mapping
#set workspace
mxd = arcpy.mapping.MapDocument("CURRENT")
#set the dataframe
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
cities = arcpy.mapping.ListLayers(mxd, "Cities")[0]
#Establish variables
cityName = arcpy.GetParameterAsText(0)
#Set variable as the parameter for the city search
arcpy.SelectLayerByAttribute_management("Cities", "NEW_SELECTION", " CITY_NAME = 'cityName' ")
df.zoomToSelectedFeatures()
arcpy.RefreshActiveView()
DanPatterson_Retired
Garrett
Code Formatting... the basics++
And the error messages you are getting would be useful, it could be in a number of those lines.
WesMiller
Regular Contributor III
import arcpy
#set the dataframe
arcpy.SelectLayerByAttribute_management(cities, "NEW_SELECTION", "CITY_NAME = '{}' ".format(cityName))
GarrettPullis
New Contributor II
The interesting thing was I wasn't receiving any errors. The script would
run through and complete, but nothing would happen in ArcMap. Prior to that
there was an error saying GetParameter wasn't defined. Besides that it
runs, but nothing happens.
AdrianWelsh
MVP Honored Contributor
Garrett,
If it isn't doing anything, can you tell if the active view got refreshed? After you run the script, are your items being selected (maybe manually refresh your view just to see)?
GarrettPullis
New Contributor II
The only thing that we were able to make it do was select all the cities
rather than the one particular city that we input
WesMiller
Change this line
to
cityName = 'A Known City Name'
WesMiller
In your original script this line
would have run successful without selecting anything unless you have a value of 'cityName'
This line
is used for an external variable most common would be model builder
