Creating a text file on python
1941
5
07-20-2012 03:20 PM
ZulyG
[PHP][/PHP]
I have a toolbox where I have created a python script. I am trying to create a text file called draft where I am writting in some information. Every time I run my script I get the followign error:
<type 'exceptions.IOError'>: [Errno 13] Permission denied: 'draft'
Failed to execute (Script).
However, when I go to properties and and "re-set" the source, the script it works again, eventhough the previous source was the correct source. The script will then run fine until I close ArcMap and open it again. I get the same error and once I "re-set" the source it works again.
Any ideas?
DanPatterson_Retired
do you have line in your script that says
arcpy.overWriteOutputs = 1
and if you open the output from the first run you won't be able to overwrite it in any event
ZulyG
[/HR]
I don't have a line in my script that says "arcpy.overWriteOutputs = 1"
I am creating the text file so there is no previous file with that name. Every time I run it, at the end of the script I delete the file.
But I only get the error when I open open ArcMap/ArcCatalog for the first time.
VikramS
Do you check if the file already exists before calling the delete function
check like below
import os
if os.exists(Full path of the text file"):
       os.delete(Full path of the text file)
ChrisBater
Try something like this.....
import os
draftFileName = r'd:\temp\draft.txt'
draftFile = open(draftFileName, 'w')
#do stuff
draftFile.close()
if os.path.exists(draftFileName):
    os.remove(draftFileName)
ZulyG
check like below
import os
I do have a file that checks if the file already exists ..and it comes out false
