Creating cursor inside or outside loop
449
10-14-2019 03:45 AM
leonoestergaard
Hi
 Here is my issue
If I create an insert cursor outside a for loop all inserted rows ends up with the same shape.
If I create the cursor inside the for loop i end up with the result that i expected
Sorry for code in image files, however this community editor seems to kill my indends
The first example the cursor is created outside the loop
 The result:
If i move the creation of the cursor inside the loop
The result:
Why am I getting diffrent results?
JoshuaBixby
How many items are in nogleboksDict?  And, how are you selecting the records in your screenshots?
DanPatterson_Retired
leonoestergaard
Joshua Bixby‌  178 items in the dictionary. Im using "select by attributes" and querying with at like on a text field
