deflection angle script
1886
16
11-29-2018 09:50 AM
JimFritz
After running the script below the "point" layer that is created does not have any features and of course no angles calculated.  Any ideas on why this might be would be appreciated.
Jim
import math
02.... sr = arcpy.Describe("Z77").spatialReference
03.... arcpy.CreateFeatureclass_management('in_memory','points',"POINT",spatial_reference=sr)
04.... arcpy.AddField_management('points','Angle',"DOUBLE")
05.... insCur = arcpy.da.InsertCursor("points",('SHAPE@','Angle'))
06.... with arcpy.da.SearchCursor("Z77",["SHAPE@"]) as cursor:
07....    for row in cursor:
08....        for part in row[0]:
09....            pt_count = 1
10....            for pnt in part:
11....                pnt = arcpy.PointGeometry(pnt,sr)
12....                if pt_count > 1:
13....                    if pt_count >2:
14....                        distAB = oneBack.distanceTo(twoBack)
15....                        distBC = pnt.distanceTo(oneBack)
16....                        distAC = pnt.distanceTo(twoBack)
17....                        angB = math.degrees(math.acos((((distAB*distAB)+(distBC*distBC))-(distAC*distAC))/(2*distAB*distBC)))
18....                        insCur.insertRow((oneBack,angB))
19....                    twoBack = oneBack
20....                oneBack = pnt
21....                pt_count += 1
22.... del insCur
Tags (1)
JimFritz
Darren,
Disregard the last response.  Print statements seem correct.  Going back to original script now.
Jim
JimFritz
Darren,
Here's the latest results using the original script.  Seems the print functions are working up to "print (angB)" and then nothing is returned.  Any ideas?
angle deflection script
DarrenWiens2
MVP Honored Contributor
Check your indentation and notice that pt_count never gets incremented, so it's never > 1.
The idea to debug this is to try to figure why the print statement never gets executed, which is because it never gets into the loop. Why not?
JimFritz
Thanks, I'll double-check the indentation issues when pasting in the code to the python window.
DanPatterson_Retired
print pnt_count rather than the point object
JimFritz
Would that be coded like this?
pt_count = 1
print (pt_count)  or  print("pt_count")
thanks,
Jim
JimFritz
Thanks Darren and Dan.  It came down to incorrect indentation.
Problem solved!
