Delete empty Feature Classes from GDB
6304
16
04-10-2015 07:02 AM
ThomasWhite4
New Contributor II
Hello,
I have many feature classes in multiple gdbs that have empty feature classes. Is there anyway to automate a process to look through each .gdb, find the empty feature classes, and to delete the empty feature classes from the .gdb?
Thank you for your time all!
Regards,
Tom
JamesCrandall
MVP Frequent Contributor
There's a scroll bar on the bottom of the code area.  It's all there!
If that is what you needed then please mark it as the answer.  If not then mark Christian's answer as the solution since he posted it up first.  It helps others find the answer if they search for the same thing.
ThomasWhite4
New Contributor II
Sorry about that, I am new to this environment. I am not returning anything on the code listed above. After running module, nothing is returned. Anything on this?
JamesCrandall
Post your code exactly as you have it written.  We can't guess.
ThomasWhite4
New Contributor II
import arcpy
arcpy.env.workspace = "D:\test_script\clip.gdb"
fcList = arcpy.ListFeatureClasses()
for fc in fcList:
     result = arcpy.GetCount_management(fc)
     count = int(result.getOutput(0))
     if count == 0:
          arcpy.Delete_management(fc)
JamesCrandall
Your workspace is incorrect or doesn't exist.  Double-check that path/name/etct..  This will print "fcList is None!" if it doesn't find it:
import arcpy
if not fcList is None:
 for fc in fcList:
      if count == 0:
else:
ThomasWhite4
New Contributor II
All works and all is fixed! Thank you for your time!
JoshuaBixby
MVP Esteemed Contributor
This is the best suggestion.  Using ArcPy Walk is by far the most Pythonic approach to enumerating data sets.
