DescribeData: Method spatialReference does not exist
6711
09-05-2011 08:13 PM
HenryColgate
I encountered this problem running a Python script and the only related thread states the solution is running 'Describe' rather than 'DescibeData'.  The problem is then resolved but as a work around rather than a solution.  However it is stated specifically that 'Describe' was being used in the first place.
http://forums.arcgis.com/search.php?searchid=654992
I am encountering the same problem and am definitely using 'Describe' also.  Specifically
desc = arcpy.Describe('C:\\image.ers\\Band_1')
datum = desc.spatialReference.datumName
cellSizeVal = desc.meanCellWidth
The reason I am using Band_1 is that the Mean Cell Width method only works on some of the data when I specify this.  Otherwise the error "DescribeData: Method meanCellWidth does not exist" occurs.  Once again this is a reference to 'DescribeData' when using 'Describe'.  On the other hand sometimes 'Band_1' does not exist for DEM files.  I would have thought this referenced only a single band with a default of Band_1 for us people out here in user land.  Should I remove 'Band_1' from the Describe input then I get the same "DescribeData: Method spatialReference does not exist" error again.
In addition to this I also get nothing as a value in some cases when I run the 'desc.spatialReference.datumName' method and it does not produce an IOError.  While this is a legitimate failure of a user to assign a coordinate system in some cases in others the data is found easily in ArcCatalog.
MichaelNesius
I'm encountering the same problem as described above, any ideas?
I've been using 10.1 sp1 for a while and the script tool which started throwing this error recently (it has worked without problems several times in the recent past)...DescribeData Method spatialReference does not exist
I don't use DescribeData anywhere, just spatial_ref=arcpy.Describe(ras).spatialReference
thanks for any help/suggestions.
-Mike
MichaelNesius
I just ended all of my arcmap processes in task manager, then reopened and ran the script and now it works fine again...perhaps some strange locking behavior effecting arcpy?
TylerSearls2
New Contributor III
I've run into the same issue as described here: Describe Data: Method spatialReference Does Not Exist.
