Processes within a pool don't share memory unless objects are passed as specific multiprocessing data types, e.g., multiprocessing.Array . Since you are not doing that in your code (I am not even sure any ArcPy objects can be passed that way), the in-memory workspace in each worker process is independent of the others.
An example:
from multiprocessing import Pool
import arcpy
import time
i = 0
def f(x):
global i
i += 1
arcpy.CreateTable_management("in_memory", "xx{}".format(i))
time.sleep(1)
arcpy.env.workspace = "in_memory"
return arcpy.ListTables()
if __name__ == '__main__':
with Pool(4) as p:
print(p.map(f, range(6)))
Yields:
[['xx1'], ['xx1'], ['xx1'], ['xx1'], ['xx1', 'xx2'], ['xx1', 'xx2']]
As you can see, each of the four worker processes is able to create the same-named table in its in-memory workspace, and each arcpy.ListTables() only sees the tables in its own in-memory workspace.
