I have a standalone python script that runs on our ArcGIS 10.7.1 server nightly to regenerate a tile cache. The script runs fine when I use an admin server connection file, but when I switch to a publisher connection I am getting the error 000732:
Input Service: Dataset <path to server connection file>\<service name>.Mapserver does not exist or is not supported
Failed to execute (ManageMapServerCacheTiles).
However, the dataset does exist at the path specified on the server. The publisher connection file uses a user that is a publisher on the server. Connection file was created in ArcMap. When I regenerate the tiles in ArcMap using the same publisher connection all works fine.
Here is the script:
import arcpy
from arcpy import env
import os, sys, time, datetime, traceback, string
env.workspace = "C:/data"
connectionPath = r"<drive letter>:\Scripts\ManageMapServerCacheTiles"
server = "<publisher connection file name>.ags"
serviceName = r"<service name>.MapServer"
database = "<sde connection file>.sde"
featureClass = "<feature class name>"
inputService = connectionPath + "\\" + server + "\\" + serviceName
scales = [<list of scales>]
numOfCachingServiceInstances = 3
updateMode = "RECREATE_ALL_TILES"
areaOfInterest = ""
waitForJobCompletion = "DO_NOT_WAIT"
updateExtents = connectionPath + "\\" + database + "\\" + featureClass
currentTime = datetime.datetime.now()
arg1 = currentTime.strftime("%H-%M")
file = connectionPath + "\\report_%s_<cache name>.txt" % arg1
report = open(file,'w')
try:
starttime = time.clock()
result = arcpy.ManageMapServerCacheTiles_server(inputService, scales,
updateMode,
numOfCachingServiceInstances,
areaOfInterest, updateExtents,
waitForJobCompletion)
finishtime = time.clock()
elapsedtime= finishtime - starttime
while result.status < 4:
time.sleep(0.2)
resultValue = result.getMessages()
report.write ("completed " + str(resultValue))
print "Created cache tiles for given schema successfully for " +\
serviceName + " in " + str(elapsedtime) + " sec on " + arg2
except Exception, e:
tb = sys.exc_info()[2]
report.write("Failed at step 1 \n" "Line %i" % tb.tb_lineno)
report.write(e.message)
report.close()
print "Created Map server Cache Tiles "
The error occurs on line 36.
What would be the reason that the script will run with an admin connection but not a publisher connection, and using the same publisher connection in Desktop I can regenerate all tiles?
