Error in using arcpy.SetParameterAsText
1742
03-22-2018 09:45 AM
JustinBridwell
New Contributor II
Hey All,
     I am trying to create a derived output using a Python script. when I run the script, I keep getting the following error:
"RuntimeError: Object: Error in setting parameter as text". I have an output folder that is an input (outFolder). I basically want to use that same folder as an output once the script has run so that I can use it in a model.
My parameters are set up like this:
input_FC = arcpy.GetParameterAsText(1)
inField = arcpy.GetParameterAsText(2)
theFName = arcpy.GetParameterAsText(3)
outFolder = arcpy.GetParameterAsText(4)
output = arcpy.SetParameterAsText(5, outFolder)
script = sys.argv[0]
I have tried several variations of SetParameterAsText, including:
        outFolder = arcpy.SetParameterAsText(5, "outFolder")
        and
My parameter named "output" is configured as such in the script tool properties:
Screenshot of my parameter settings
It is set to derived so that it will appear as an output in a model and obtained from the input parameter, outFolder (Named Feature Class in the parameter settings above). What am I doing wrong here?
VishalShah2
Occasional Contributor II
My first thought to solve this is have the first parameter as text set with an index of 0.
input_FC = arcpy.GetParameterAsText(0)
inField = arcpy.GetParameterAsText(1)
theFName = arcpy.GetParameterAsText(2)
outFolder = arcpy.GetParameterAsText(3)
output = arcpy.SetParameterAsText(4, outFolder)
See if that solves it.
VishalShah2
XanderBakker
Esri Esteemed Contributor
You should start numbering with 0, not 1. Index number 5 does not exist.
JustinBridwell
New Contributor II
Hey Guys- You are both absolutely correct. For whatever reason, I thought that arcpy.SetParameterAsText started its index at 1. This was the crux of my whole problem. It works beautifully now. Thanks so much.
ADEBOLAHASSAN
Hello Justin, i have the same problem now and i have to input it in my thesis defense next week, is it possible to see what the whole of your script looks like?
Thanks
Adebola
VishalShah2
What exactly seems to be your problem? Post the script here and what your script tool parameters look like.
