What is the bug in this scenario? I have used the following bit of code (last chunk in a long script) 5 times successfully (on 5 different batches of rasters) and now the 6th time it refuses to work, alternately giving me error 000354: "The name contains invalid characters", or 99999: "Something unexpected caused the tool to fail", depending on how I try to fix it.
Aim: Run Zonal Statistics as Table on time series batches of binary threshold rasters to observe growth of plants.
I got it to run smoothly following this post: https://gis.stackexchange.com/questions/206559/python-script-zonal-stats-as-table-loop-question.
The only change I can see in this latest batch of rasters it that my "zones" shapefile exceeds 36KB. There are no Null values in "Id", the fieldname is not longer than 17 characters, there are only 2 values present in the rasters (binary otsu threshold), and the feature zone dataset is comprised of 276 zones, far less than the 170,000 features at which problems are supposed to present themselves. I tried all the solutions and workarounds found here: https://support.esri.com/en/technical-article/000012343.
Any suggestions are more than welcome.
The code snippet:
import os, glob, shutil, arcpy, cv2
import numpy as np
from arcpy import env
from arcpy.sa import *
from arcpy import UpdateCursor
env.overwriteOutput = True
#Create table of stats for each threshold using vectorized tray zones
try:
env.workspace = "O:/NeilsonJ/Image_Processing/Working/150719/6.Scaled"
for raster in arcpy.ListRasters():
print (raster)
run9_1_2019-15-28-10-52_dist_NXG_OTSU_scaled.tif
run9_1_2019-15-28-11-52_dist_NXG_OTSU_scaled.tif
run9_1_2019-15-28-12-52_dist_NXG_OTSU_scaled.tif
run9_1_2019-15-28-13-52_dist_NXG_OTSU_scaled.tif
outDir = "O:/NeilsonJ/Image_Processing/Working/150719/7.Tables"
inZoneData = "O:/NeilsonJ/Image_Processing/Working/150719/150719_tray.shp"
raster_name = os.path.basename(raster).rstrip(os.path.splitext(raster)[1])
outTable = os.path.join(outDir, raster_name +".dbf")
arcpy.gp.ZonalStatisticsAsTable(inZoneData, "Id", raster, outTable, "NODATA", "ALL")
except:
print ("Script failed to complete")
print (arcpy.GetMessages(2))
ERROR 000354: The name contains invalid characters
Failed to execute (ZonalStatisticsAsTable).
##WHEN IT WORKS (19513_195514 has already been completed)
env.workspace = "O:/NeilsonJ/Image_Processing/Working/19513_19514/7.Tables"
for table in arcpy.ListTables():
print (table)
run7_27__dist_NXG_OTSU_scaled.dbf
run7_21__dist_NXG_OTSU_scaled.dbf
run7_7__dist_NXG_OTSU_scaled.dbf
run7_33__dist_NXG_OTSU_scaled.dbf
