Error when running custom script tool
5182
13
05-20-2016 07:01 AM
SadanandacharB1
New Contributor III
Hi All
  I am getting error when running custom created script tool to copy feature classes from folder to geodatabase
below is the error
  File "D:\Python DVD\Python\Data\Exercise02\CopyFeature.py", line 9, in <module>
    arcpy.CopyFeatures_management(fc, os.path.join(outgdb, fcdesc.basename))
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 2429, in CopyFeatures
    raise e
ExecuteError: ERROR 000210: Cannot create output E:\ArcPy\ResultFeatures\basin
Failed to execute (CopyFeatures).
Failed to execute (MyCopy).
What am i missing, Please help me
DanPatterson_Retired
and the script? the details are within
BenjaminMittler
Occasional Contributor III
It doesn't look as if there is a geodatabase in your output file path, based on the error you are receiving.
curtvprice
MVP Esteemed Contributor
From what I can see Benjamin hit the nail on the head. Workspaces can be folders or geodatabases.
Your second tool parameter should be an existing geodatabase, that is "E:\ArcPy\ResultFeatures\Test1.gdb" (instead of a folder:  "E:\ArcPy\ResultFeatures").
You can set the parameter Filter property to exclude folders - this will prevent you from providing a folder name for the second argument by mistake. Also -- make sure this parameter is of type Input to make sure you provide the path to an existing geodatabase.
SadanandacharB1
New Contributor III
Thank you so much for your HELP
AdrianWelsh
MVP Honored Contributor
Hi Sadanandachar,
Can you post the script?
SadanandacharB1
New Contributor III
Hi below is my script created  for custom tool
import arcpy
import os
from arcpy import env
env.workspace = arcpy.GetParameterAsText(0)
outgdb = arcpy.GetParameterAsText(1)
fclist = arcpy.ListFeatureClasses()
for fc in fclist:
    fcdesc = arcpy.Describe(fc)
You should keep these links handy
What is ArcPy?—Help | ArcGIS for Desktop
ArcInfo Workstation Item properties—Help | ArcGIS for Desktop
Describe object properties—Help | ArcGIS for Desktop
and particularly
env—Help | ArcGIS for Desktop with the overwriteOutput option.  Sometime a 'can't create... means that it already exists and can't be overwriten since env.overwriteOutput = True needs to be set
AdrianWelsh
Oooh, that's a good one. Forgot about:
That may be the issue here.
SadanandacharB1
New Contributor III
Thank you very much
