ET Surface scripting error - takes no arguments
3845
03-24-2015 08:51 PM
MalcolmNunn
Hi all
Trying to automate some contour generation with ET Surface using a script.
The following script generates the error 'ETS_GPIDW() takes no arguments (7 given)'.
import arcpy
arcpy.ImportToolbox(r"C:\Program Files (x86)\ET SpatialTechniques\ET Surface 6.0 for ArcGIS 10.1\ET Surface.tbx")
arcpy.ETS_GPIDW("C:\points.shp", "C:\Sal.img", "Sal", 2, 5, 43, 5000)
I've tried running it from the command line within ArcMap and it works just fine.
ArcMap 10.1 and ET Surface 6.0.
Any ideas?
Cheers
Mal
DarrenWiens2
MVP Honored Contributor
Sorry to say, but I can't reproduce your error. I'm using version 6.0 for 10.2. I don't see anything wrong with your syntax - the backslash situation in the call to ETS_GPIDW raised an eyebrow, but I could also save to \Sal.img and \pSal.img, so I don't think that's it. This works for me:
import arcpy
arcpy.ImportToolbox(r'C:\Program Files (x86)\ET SpatialTechniques\ET Surface 6.0 for ArcGIS 10.2\ET Surface.tbx')
arcpy.ETS_GPIDW("C:\junk\csv_points.shp", "C:\junk\idw.img", "Elev", 25, 2, 12, 2000)
