I've just upgrade from ArcGIS 10 to 10.1 and I've run into a problem with some of my scripts. I'm using FeatureClassToGeodatabase_conversion to extract data from a non-spatial SQL Server table. The input I am using is a layer file using a "Definition Query" to limit the features that I create. This worked fine in 10.0, but in 10.1 it seems to be ignoring the definition query so I get the entire table. I've tried switching to FeatureClassToFeatureClass_conversion and that does the same, and when I try to use the where_class on that call I get the error "000339 : Input <value> does not have OIDs". Does anybody have any suggestions?
