I am trying to generate a number of service profiles using the arcpy nax network analyst library. The idea is to create a profile for each of the models (impedance values) we use, and also some standard cut off times that we use.
The script appears to work but does not apply either the Additional Time mapped field name, or the default value. In the output facilities layer the value for all locations is 0.
I've made sure that the value in the turnout field is a double.
Any ideas what the issue could be.
import arcpy
arcpy.CheckOutExtension("network")
roadNetwork = r"C:\aaa\rnm\2022_04.gdb\Core_VG2020\RoutingApplication_ND"
nd_layer_name = "Routing_ND"
#inFacilities = r"J:\projects\netmodels\04 Data\Turnout Times\FY2122_Q3\data.gdb\FY2022_Q3_Brigades_w_TOT"
inFacilities = r"C:\aaa\rnm\Statewide_Profiles\Resp_Profiles_2022_04.gdb\inside"
turnoutTimeField = "turnout"
additional_fields = ['turnout_id', 'short_name', 'brig_name', 'brig_no', 'distrct_no', 'turnout_mins',
turnoutTimeField]
toolOutput = r"C:\aaa\rnm\Statewide_Profiles\Resp_Profiles_2022_04.gdb"
outputName = "Resp_Profiles_2022_041"
models = ['ARRB_Min', 'ARRB_Mean', 'ARRB_Max', 'EmergencyServicesTime', 'GLM_Pumper_Off_Peak', 'GLM_Pumper_Peak',
'GLM_Tanker_Off_Peak', 'GLM_Tanker_Peak']
breakValues = [8, 10, 20]
travel_mode_name = "CFA"
# Create a network dataset layer and get the desired travel mode for analysis
arcpy.nax.MakeNetworkDatasetLayer(roadNetwork, nd_layer_name)
nd_travel_modes = arcpy.nax.GetTravelModes(nd_layer_name)
travel_mode = nd_travel_modes["CFA"]
service_area = arcpy.nax.ServiceArea(nd_layer_name)
# Set properties
service_area.outputType = arcpy.nax.ServiceAreaOutputType.Polygons
service_area.geometryAtOverlap = arcpy.nax.ServiceAreaOverlapGeometry.Overlap
service_area.polygonDetail = arcpy.nax.ServiceAreaPolygonDetail.Standard
additional_fields_objects = [f for f in arcpy.ListFields(inFacilities) if f.name in additional_fields]
field_mappings = service_area.fieldMappings(arcpy.nax.ServiceAreaInputDataType.Facilities,
list_candidate_fields=additional_fields_objects)
field_mappings["AdditionalTime"].mappedFieldName = turnoutTimeField
field_mappings["AdditionalTime"] = 6.0
service_area.load(arcpy.nax.ServiceAreaInputDataType.Facilities, inFacilities, field_mappings)
for model in models:
travel_mode.impedance = model
travel_mode.timeAttributeName = model
service_area.travelMode = travel_mode
for cutoff in breakValues:
service_area.defaultImpedanceCutoffs = cutoff
result = service_area.solve()
if result.solveSucceeded:
output_fc = f"{toolOutput}\\{outputName}_{model}_{cutoff}"
result.export(arcpy.nax.ServiceAreaOutputDataType.Polygons, output_fc)
result.export(arcpy.nax.ServiceAreaOutputDataType.Facilities, output_fc + "_fac")
else:
print("Solve failed")
print(result.solverMessages(arcpy.nax.MessageSeverity.All))
