Verbose demo with constructed featureclass... only 5 records, number isn't relevent, can create output directly.
# coding: utf-8
Script: interpolate_demo.py
Author: Dan.Patterson@carleton.ca
Purpose: To demonstrate interpolation using values in ndarrays
field names constructed using the following to simplify dt
dt_names = ["v"+str(i) for i in range(N)]
dt = [(dt_names, "<f8") for i in range(N)]
Array should be constructed using arcpy.da.FeaturelassToNumPyArray
RI - time relationships are on a row by row basis, could be greatly
simplified if there were fewer, but not needed
import numpy as np
np.set_printoptions(edgeitems=3,linewidth=80,precision=2,suppress=True,
threshold=20, formatter={'float': '{: 0.3f}'.format})
# fix dtype
dt = [('OIDName', '<i4'), ('Shape', '<f8', (2,)), ('obs', '<f8'),
('v0', '<f8'), ('v1', '<f8'), ('v2', '<f8'), ('v3', '<f8'),
('v4', '<f8'), ('v5', '<f8'), ('v6', '<f8'), ('v7', '<f8')]
a = np.array([(0, [0,0], 7.5, 1, 3, 5, 10, 20, 50, 100, 200),
(1, [1,2], 15.0, 1, 3, 5, 10, 20, 50, 100, 200),
(2, [3,4], 75.0, 1, 3, 5, 10, 20, 50, 100, 200),
(3, [5,6], 35.0, 2, 4, 6, 11, 25, 50, 140, 225),
(4, [7,8], 9.0, 3, 5, 7, 10, 22, 40, 120, 230)], dtype=dt)
# ---- It begins below
t = [5,10,20,50,100,200,500,1000] # fixed time increments
obs = a["obs"] # we know the name so use it
ri_names = list(a.dtype.names[3:]) # could type in a long list
RI_s = a[ri_names] # RI curve values
N = len(obs) # number of records
# -- the magic of list comprehensions, could vectorize, but hey...
result = [ (a["OIDName"], a["Shape"].tolist(), obs,
np.interp(obs, RI_s.tolist(), t) )
for i in range(N)]
dt_out = [('OIDName', '<i4'), ('Shape', '<f8', (2,)),
('obs', '<f8'), ('RI_2', '<f8')]
out_array = np.array(result, dtype=dt_out)
# Could send out_array to a featureclass using NumPyArrayToFeatureClass
#---- The rest is fluff
print("\nInput ndarray \n{}\ndtype {}\nShape {}\n".format(a, a.dtype, a.shape))
print("\nViewed differently\n{}".format(a.reshape((-1,1))))
print("\nResults...\nTimes {}\n{}".format(t,out_array.reshape((-1,1))))
Outputs
Input ndarray
[(0, [0.0, 0.0], 7.5, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)
(1, [1.0, 2.0], 15.0, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)
(2, [3.0, 4.0], 75.0, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)
(3, [5.0, 6.0], 35.0, 2.0, 4.0, 6.0, 11.0, 25.0, 50.0, 140.0, 225.0)
(4, [7.0, 8.0], 9.0, 3.0, 5.0, 7.0, 10.0, 22.0, 40.0, 120.0, 230.0)]
dtype [('OIDName', '<i4'), ('Shape', '<f8', (2,)), ('obs', '<f8'),
('v0', '<f8'), ('v1', '<f8'), ('v2', '<f8'), ('v3', '<f8'), ('v4', '<f8'),
Shape (5,)
Viewed differently
[[(0, [0.0, 0.0], 7.5, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)]
[(1, [1.0, 2.0], 15.0, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)]
[(2, [3.0, 4.0], 75.0, 1.0, 3.0, 5.0, 10.0, 20.0, 50.0, 100.0, 200.0)]
[(3, [5.0, 6.0], 35.0, 2.0, 4.0, 6.0, 11.0, 25.0, 50.0, 140.0, 225.0)]
[(4, [7.0, 8.0], 9.0, 3.0, 5.0, 7.0, 10.0, 22.0, 40.0, 120.0, 230.0)]]
Results...
Times [5, 10, 20, 50, 100, 200, 500, 1000]
[[(0, [0.0, 0.0], 7.5, 35.0)]
[(1, [1.0, 2.0], 15.0, 75.0)]
[(2, [3.0, 4.0], 75.0, 350.0)]
[(3, [5.0, 6.0], 35.0, 140.0)]
[(4, [7.0, 8.0], 9.0, 40.0)]]
Values against average RI data
# averages
RI_avg = np.mean(RI_s.tolist(),axis=0)
t = [5,10,20,50,100,200,500,1000] # fixed time increments as before
obs = a["obs"] # as before
result2 = np.interp(obs, RI_avg.tolist(), t)
>>> result2
array([ 32.391, 71.429, 326.562, 151.128, 42.174])
Plus other combinations if needed
