I have a service that chooses whether to give a field one value or another depending on what's present in the data already. When I run the python script outside of the server, it runs fine. When I run it on the server, it fails because it doesn't recognize the uuid module in the code block. I think it's treating uuid as a string, but to use code blocks you pass in the whole code block as a string. Has anybody successfully used code blocks in their GP services?
def getTractID(isDuplicate):
import uuid
if isDuplicate == 'dupe':
tractID = '{' + str(uuid.uuid4()) + '}'
tractID = tractID.upper()
arcpy.RemoveJoin_management(mgmtTractFL)
with arcpy.da.UpdateCursor(mgmtTractFL, 'MgmtTractID') as uCursor:
for row in uCursor:
row[0] = tractID
uCursor.updateRow(row)
del uCursor
arcpy.AddJoin_management(mgmtTractFL, 'OBJECTID', duplicatePolys, 'IN_FID')
else:
codeblock = """def ID():
return '{' + str(uuid.uuid4()) + '}'"""
expression = 'ID().upper()'
arcpy.CalculateField_management(mgmtTractFL, 'MgmtTractID', expression, 'PYTHON', codeblock)
On my server it converts 'ID().upper()' into a g_ESRI_variable. I still don't get why it would affect it's efficacy though. The 'expression' variable would still be a string.
g_ESRI_variable_3 = u'ID().upper()'
g_ESRI_variable_4 = u'MgmtTractID'
import uuid
else:
expression = g_ESRI_variable_3
arcpy.CalculateField_management(mgmtTractFL, g_ESRI_variable_4, expression, 'PYTHON', codeblock)
If this can't be figured out, I can always use a cursor but I figure CalculateField would be faster when there's 1000+ records.
