geoprocessing tool output parameter
458
10-04-2013 12:04 AM
OndrejRenner
I have a python script which publish as a geoprocessing tool on ArcGIS Server 10.1.
Output of this script is object (Output class instance) of this structure:
class StatisticalParams:
    def __init__(self, type, min, max, std, mean, count):
        self.type = type
        self.min = min
        self.max = max
        self.std = std
        self.mean = mean
        self.count = count
class Feature:
    def __init__(self, fid, ftype, statisticalParams):
        self.fid = fid
        self.ftype = ftype
        self.statisticalParams = statisticalParams
class Output:
    def __init__(self, statisticalParam, features):
        self.statisticalParam = statisticalParam
        self.features = features
I do not know how I should set output parameter on ArcGIS Server (configuration of parameters of the script). In the script parameter is sets as
arcpy.SetParameter (1 outputParam)
Thanks for help.
Rendy
SchoppMatthieu
Maybe you could convert it to json and then return it as string :
import json
outputJson = json.dumps(outputParam)
arcpy.SetParamter(outputJson )
