Get FGDB database view's SQL definition using Python
278
05-11-2023 10:28 AM
Bud
Notable Contributor
ArcGIS Pro 3.1.1
Is there a way to get a FGDB database view's SQL definition using Python?
For example, I have a file geodatabase database view called TEST_TABLE_VW:
select objectid, case when type = 'NT' then 1 else 0 end as flag from test_table
Is there a way to assign that SQL text to a Python variable, print it, etc.?
DannyMcVey
The describe object for tables has a "whereClause" property. That should do it.
import arcpy
# Create a table view from a feature class
if arcpy.Exists("view"):
    arcpy.Delete_management("view")
arcpy.management.MakeTableView(
    in_table="a",
    out_view="view",
    where_clause="OID = 0",
# Create a Describe object from the table view
desc = arcpy.Describe("view")
# Print some table view properties
print(f"Table View Name: {desc.nameString}")
print(f"Where Clause:    {desc.whereClause}")
print(f"Table Name:      {desc.name}")
DannyMcVey
import arcpy
    in_table="a",
    out_view="view",
