Hello, Python coders:
Your hands-on assistance on the following Python third-party packages' upgrade would be appreciated:
Description:
ArcGIS 10.3 users would like to use the package "Site.py" (or other similar tool) and then to install/ upgrade the third-party Python package "scikit-learn" with "scipy" into the following Windows third-party Python path (i.e., C:\Python27\ArcGIS10.3\Lib\site-packages), so that data engineers can use ArcGIS to directly call the functions from "scikit-learn" and "scipy" inside ArcGIS 10.3 (Python 2.7.8), without troubles.
Note:
When ArcGIS 10.3 was installed into Windows 7, Python 2.7.8 was also installed into: C:\Python27\ArcGIS10.3 ;
With Python 2.7.8, the two third-party packages "NumPy" and "Matplotlib" also available under the folder: C:\Python27\ArcGIS10.3\Lib\site-packages ;
The 'built' Windows Python package "scikit-learn" with "scipy" locates at the folder: D:\Python-Packages\ ;
Question:
What is the python "script" more effectively to do this upgrade task?
It would be better to install /upgrade the third-party Python packages,without Admin privilege (if required, please indicated) .
