How can I use the Intersect tool to find common areas from 3 output files created by an Iterator tool in a Model Builder?
3943
05-05-2015 10:32 AM
abubadruddin
abubadruddin
Here is the screen shot of my Model. It selects 3 different school using the Iterator tool from the Parcel layer and creates a 3 mile buffer around each of the 3 schools and save them as School1_Buffer, School2_Buffer, & School3_Buffer. So this model works as expected!
However, I want to find the common areas among those 3 school buffer (School1_Buffer, School2_Buffer, & School3_Buffer). How can I use the Intersect tool in the model to create an intersect among those 3 buffers?
DarrenWiens2
MVP Honored Contributor
If you're asking because Basic and Standard licenses only allow two inputs for Intersect, you can get around it by running the tool once between feature classes 1 and 2, then again with the output and feature class 3.
BlakeTerhune
MVP Regular Contributor
Check out the Intersect Help Topic, there are some helpful Python code examples at the bottom. The function can take all three of your output files as a list for input.
SepheFox
Hi Abu, It might be helpful to post a screenshot of your model.
abubadruddin
